Greetings, according to this mailing list there doesn't exist a tool for
batch importing shapefiles into GeoServer, so I thought I'd write one. Could
you please have a look at my algorithm and let me know what steps I am
missing:
def shp2geoserver(shp,datastoreid,sld,srs):
copy the shapefile to data_dir\data
add the new shapefile as a datastore element to data_dir\catalog.xml
create index.xml under the data_dir\featureTypes\datastoreid dir
To run my script I stop GeoServer, run it, start GeoServer. The outcome is:
-the directories/files are populated as per the algorithm
-I can see the newly added datastores under
http://localhost:8080/geoserver/config/data/store.do
-I can't see the newly added features under
http://localhost:8080/geoserver/config/data/typeSelect.do
Could someone please tell me what I am doing wrong? Am I forgetting to
update some config files? Is this at all doable?
Here is some sample data:
added to <datastores> in catalog.xml
<datastore enabled="true" id="ds_south_australia_poly" namespace="topp">
<connectionParams>
<parameter name="create spatial index" value="true" />
<parameter name="namespace" value="topp" />
<parameter name="url"
value="file:data/Topo_GA/100K/south_australia_poly.shp" />
<parameter name="charset" value="ISO-8859-1" />
</connectionParams>
</datastore>
...\data_dir\featureTypes\ds_south_australia_poly\index.html:
<featureType datastore = "ds_south_australia_poly" >
<name>south_australia_poly</name>
<SRS>4283</SRS>
<SRSHandling>0</SRSHandling>
<title>south_australia_poly_Type</title>
<abstract>Generated from ds_south_australia_poly</abstract>
<wmspath>/</wmspath>
<numDecimals value = "8" />
<keywords>south_australia_poly ds_south_australia_poly</keywords>
<latLonBoundingBox dynamic = "false" miny = "-43" maxy = "-25" maxx =
"141" minx = "129" />
<nativeBBox dynamic = "false" miny = "-43" maxy = "-25" maxx = "141" minx
= "129" />
<styles default = "south_australia_poly" />
<cacheinfo enabled = "false" maxage = "" />
<maxFeatures>0</maxFeatures>
</featureType>
Many thanks,
Stoyan.
PS: I'll gladly publish the script here, once I get it working.
View this message in context: http://www.nabble.com/shp2geoserver%3A-batch-import-for-shapefiles-tp18189529p18189529.html
