Thanks: I hadn’t noticed that page before:
http://docs.geoserver.org/latest/en/user/styling/sld-tipstricks/transformation-func.html
Simon Hartley
Sent: 14 May 2014 21:05
To: Simon Hartley
Cc: Jonathan Moules; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] SLD Alternatives
I always try and teach styling using the Recode, Interpolate, and Categorize functions first - rather than conditionals. I often end up with a mix of rules based on scale, and se functions to do the work at a given zoom level.
Jody Garnett
On Wed, May 14, 2014 at 10:04 AM, Simon Hartley <SHartley@…2992…> wrote:
Hi Jonathan,
Using standard SLD is painful because once you have enough conditionals,
you end up having to repeat large blocks and the number of lines becomes huge.
One of the styles generated by the CSS extension was 20 thousand lines of SLD!
Simon Hartley
From: Jonathan Moules [mailto:jonathanmoules@…4942…]
Sent: 14 May 2014 15:19
To: Simon Hartley
Hi Simon,
Could you clarify what sorts of tasks are you looking for?
We maintain our styles within the standard GeoServer interface and find that adequate. Admittedly they’re very verbose, but once you have the form of them down they’re easy to copy/paste between them.
Jonathan
On 14 May 2014 14:18, Simon Hartley <SHartley@…2992…> wrote:
Does anyone have any recommendations for easily building and maintaining SLD styles?
We’ve tried using the GeoServer CSS extension and were initially happy with it, but we’re going to have to abandon it after major speed issues.
I can see links to a Styler project, but it doesn’t seem to have much progress. Is OpenGeo Suite any good for this?
Thanks a lot
Simon Hartley
*** This communication has been sent from World Fuel Services
Corporation or its subsidiaries or its affiliates for the intended recipient
only and may contain proprietary, confidential or privileged information.
If you are not the intended recipient, any review, disclosure, copying,
use, or distribution of the information included in this communication
and any attachments is strictly prohibited. If you have received this
communication in error, please notify us immediately by replying to this
communication and delete the communication, including any
attachments, from your computer. Electronic communications sent to or
from World Fuel Services Corporation or its subsidiaries or its affiliates
may be monitored for quality assurance and compliance purposes.***
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform available
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
