> -----Original Message-----
> From: Andrea Aime [mailto:aaime@anonymised.com]
> > Hi all,
> > It looks like this is not possible since PointSymbolizer should
> > render on the centre point of a geometry and
> LineSymbolizer appears
> > to have no capability to show only the nodes. Looks
> like I'm going
> > to have to try to extract the nodes into a seperate
> layer at the
> > database level and then render that layer as a point dataset.
> > If anyone has a better solution please let me know, cheers.
> > I've been having a little look at this - I thought perhaps
> you could
> > cheat and use the stroke-linejoin and stroke-linecap
> CssParameters to
> > place points on the nodes, whilst using a stroke-width of zero.
> If the stroke-width is 0, then the linecap and linejoin
> should have no effect whatsoever... am I missing something?
Nope - it was just something that I thought I'd try, seeing as I had no
idea about how the renderer would interprit it. When you try with a
stroke-width of greater than zero, though, the stroke-linejoin and
stroke-linecap CssParameters still had no effect in version 1.6.
Miles
___________________________________________________________________________
Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
Visit our web site at http://www.antarctica.gov.au/
