[Geoserver-users] SLD error with <Halo> tag (GeoServer 2.10)
I'm having troubles with a SLD file used within GeoServer 2.10. When checking
the syntax, it returns the following error message: /line 2542:
cvc-complex-type.2.4.a : Unvalid content from element 'Halo'. One of the
values '{"http://www.opengis.net/sld&quot;:Graphic,
"http://www.opengis.net/sld&quot;:Priority,
"http://www.opengis.net/sld&quot;:VendorOption\}' is expected./
Here is my code:
         <Rule>
          <Name>Canalisation hors-service</Name>
          <Title>Canalisation hors-service</Title>
          <ogc:Filter>
            <ogc:Not>
              <ogc:PropertyIsNull>
                <ogc:PropertyName>annee_hs</ogc:PropertyName>
              </ogc:PropertyIsNull>
            </ogc:Not>
          </ogc:Filter>
          <MinScaleDenominator>1</MinScaleDenominator>
          <MaxScaleDenominator>10010</MaxScaleDenominator>
          <LineSymbolizer>
            <Stroke>
              <CssParameter name="stroke">#dcdcdc</CssParameter>
              <CssParameter name="stroke-width">6</CssParameter>
              <CssParameter name="stroke-opacity">0.75</CssParameter>
        <CssParameter name="stroke-linecap">round</CssParameter>
            </Stroke>
          </LineSymbolizer>
          <TextSymbolizer>
            <Label>Hors-service</Label>
            <LabelPlacement>
              <LinePlacement />
            </LabelPlacement>
            <Fill>
              <CssParameter name="fill">#606060</CssParameter>
        <CssParameter name="font-family">Calibri</CssParameter>
              <CssParameter name="font-size">12</CssParameter>
              <CssParameter name="font-style">normal</CssParameter>
              <CssParameter name="font-weight">bold</CssParameter>
            </Fill>
         <Halo>
     <Fill>
      <CssParameter name="fill">#dcdcdc</CssParameter>
     </Fill>
              </Halo>
            <VendorOption name="followLine">true</VendorOption>
          </TextSymbolizer>
        </Rule>
When I delete the <Halo></Halo> lines, the error does not show up again.
This issue does not unable layer display when I test it with QGIS for
example...
Any advice on what might be wrong?
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-error-with-Halo-tag-GeoServer-2-10-tp5304454.html
LineSymbolizers don’t have halos, only TextSymbolizers do. What are you trying to do?
Ian
On 23 January 2017 at 13:00, wiltomap <wiltoma@anonymised.com> wrote:
I’m having troubles with a SLD file used within GeoServer 2.10. When checking
cvc-complex-type.2.4.a : Unvalid content from element ‘Halo’. One of the
values ‘{“http://www.opengis.net/sld”:Graphic,
http://www.opengis.net/sld”:Priority,
http://www.opengis.net/sld”:VendorOption}’ is expected./
Here is my code:
Canalisation hors-service Canalisation hors-service annee_hs 1 10010 #dcdcdc 6 0.75 round Hors-service #606060 Calibri 12 normal bold #dcdcdc true
When I delete the lines, the error does not show up again.
example…
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ian Turton
A simple matter of order in the elements, the schema says:
<xsd:element name=“TextSymbolizer” substitutionGroup=“sld:Symbolizer”>
xsd:annotation
xsd:documentation
A “TextSymbolizer” is used to render text labels according to various graphical parameters.
</xsd:documentation>
</xsd:annotation>
xsd:complexType
xsd:complexContent
<xsd:extension base=“sld:SymbolizerType”>
xsd:sequence
<xsd:element ref=“sld:Geometry” minOccurs=“0”/>
<xsd:element ref=“sld:Label” minOccurs=“0”/>
<xsd:element ref=“sld:Font” minOccurs=“0”/>
<xsd:element ref=“sld:LabelPlacement” minOccurs=“0”/>
<xsd:element ref=“sld:Halo” minOccurs=“0”/>
<xsd:element ref=“sld:Fill” minOccurs=“0”/>
<xsd:element ref=“sld:Graphic” minOccurs=“0”/>
<xsd:element ref=“sld:Priority” minOccurs=“0”/>
<xsd:element ref=“sld:VendorOption” minOccurs=“0” maxOccurs=“unbounded”/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
</xsd:element>
And you have put the halo after the fill, instead of before. Indeed, it will render anyways, it’s just
formally incorrect
Full schema here:
http://demo.geo-solutions.it/geoserver/schemas/sld/StyledLayerDescriptor.xsd
Here is my code:
example…
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Sorry miss read that, the fill section is what is wrong:
should be
#606060
Ian
Ian
Here is my code:
example…
Geoserver-users@anonymised.comrge.net
Ian Turton
Ian Turton
Many thanks to both of you! I didn't know about this order importance.
I now still have one remaining error on a CssParameter and the SLD cookbook
doesn't help me very much as the <halo> tag structure seems to be followed
properly:
/line 2542: cvc-complex-type.2.4.a : Unvalid content from element
'CssParameter'. One fo the values '{"http://www.opengis.net/sld&quot;:Radius,
"http://www.opengis.net/sld&quot;:Fill\}' is expected./
See below an extract of my code including line numbers.
<http://osgeo-org.1560.x6.nabble.com/file/n5304463/sld_error.png&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-error-with-Halo-tag-GeoServer-2-10-tp5304454p5304463.html
Again from the SLD schema linked above:
<xsd:element name=“Halo”>
xsd:annotation
xsd:documentation
A “Halo” fills an extended area outside the glyphs of a rendered text label to make the label easier to read over a background.
</xsd:annotation>
xsd:complexType
xsd:sequence
<xsd:element ref=“sld:Radius” minOccurs=“0”/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
Ing. Andrea Aime
@geowolf
Technical Lead
