Hi list,
i’m trying to bind an external graphic to use in SLD, but it doesn’t work. Here’s a snippet:
---------------------------------8<----------------------------------------------
GIF
3
the bitmap is reacheable for geoserver. I inserted the url http://localhost:9080/geoserver/bitmaps/red_cross.GIF in the browser and got the bitmap back.
The SLD also looks OK. I get no error in the log. Only these areas which are styled with above PolygonSymbolizer are white. ExternalGraphic is surely implemented for PolygonSymbolizer isn’t it?
KR
Albrecht
Albrecht Weiser,
E6, GIS Center
Hessische Zentrale für Datenverarbeitung (HZD)
Mainzer Straße 29, 65185 Wiesbaden
Tel.: 0611 340-3113
Fax: 0611 340-5113
E-Mail: albrecht.weiser-at-hzd.hessen.de
Hi Albrecht,
Which version of GeoServer are you using? I was under the impression that this should work ok in more recent versions.
-Justin
Albrecht.Weiser@anonymised.com wrote:
Hi list,
i'm trying to bind an external graphic to use in SLD, but it doesn't work. Here's a snippet:
<PolygonSymbolizer>
<Fill>
<GraphicFill>
<Graphic>
<ExternalGraphic>
<OnlineRessource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost:9080/geoserver/bitmaps/red_cross.GIF"/>
<Format>GIF</Format>
</ExternalGraphic>
<Size>3</Size>
</Graphic>
</GraphicFill>
</Fill>
</PolygonSymbolizer>
the bitmap is reacheable for geoserver. I inserted the url ___http://localhost:9080/geoserver/bitmaps/red_cross.GIF_ in the browser and got the bitmap back.
The SLD also looks OK. I get no error in the log. Only these areas which are styled with above PolygonSymbolizer are white. ExternalGraphic is surely implemented for PolygonSymbolizer isn't it?
KR
Albrecht
Albrecht Weiser,
E6, GIS Center
Tel.: 0611 340-3113
Fax: 0611 340-5113
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
Albrecht.Weiser@anonymised.com ha scritto:
Hi list,
<PolygonSymbolizer>
<Fill>
<GraphicFill>
<Graphic>
<ExternalGraphic>
</ExternalGraphic>
<Size>3</Size>
</Graphic>
</GraphicFill>
</Fill>
Hum, yes, but nothing is able to support the mime type "GIF". Try with
"image/gif", you should have better chance.
Yep, you're right, that was wrong. Unfortunately it seemed not to be the origin of the problem. I also tried to place the bitmap somewhere else on an apache web-directory; i tried with png instead of gif - nothing worked.
I'm helpless :o/
Best wishes
Albrecht
Von: Andrea Aime [mailto:aaime@anonymised.com]
Gesendet: Dienstag, 12. August 2008 15:12
An: Weiser, Albrecht (HZD)
Betreff: Re: [Geoserver-users] SLD: ExtarnalGraphic does not work
> Hi list,
it doesn't
> <PolygonSymbolizer>
> <Fill>
<GraphicFill>
<Graphic>
> <ExternalGraphic>
> xlink:type="simple"
> </ExternalGraphic>
> <Size>3</Size>
</Graphic>
</GraphicFill>
> </Fill>
in the browser
these areas which
ExternalGraphic is
Albrecht, I think you simply have a typo:
OnlineRessource - too many "s" in there - should be OnlineResource
Also, I've found that the value of Size should match the value of the
image's height for best results.
Otherwise, it can get stretched or squished or be too small. You might want
to check that just in case.
I have some working examples at these URLs if you're interested:
http://lyceum.massgis.state.ma.us/wiki/doku.php?id=wms:sld:polygon_example_diagonal_graphic&s=sld
http://lyceum.massgis.state.ma.us/wiki/doku.php?id=wms:sld:polygon_example_fill_graphics
http://lyceum.massgis.state.ma.us/wiki/doku.php?id=wms:sld:polygon_example_trans_graphic
View this message in context: http://www.nabble.com/SLD%3A-ExtarnalGraphic-does-not-work-tp18927405p18946078.html
