[Geoserver-users] SLD ExternalGraphic Problem on Geoserver 1.3.4
Hi list,
I have recently upgraded Geoserver from version 1.3.0 to 1.3.4, and after that I have noticed that External Graphics are no more shown.
Example:
<ExternalGraphic>
    <OnlineResource xlink:href="rail7.png" />
    <Format>image/png</Format>
</ExternalGraphic>
The SLD is validated, but "rail7.png" is not shown. Instead, Geoserver 1.3.0 shows the External Graphic as expected.
Is it a bug on Geoserver 1.3.4?
Eduardo
Please,
Has someone also experienced this?
Any help will be appreciated.
Eduardo
Eduardo Luís Garcia Escovar wrote:
Hi list,
Example:
<ExternalGraphic>
</ExternalGraphic>
Eduardo
Eduardo Luís Garcia Escovar ha scritto:
Please,
Eduardo
Hi list,
Example:
<ExternalGraphic>
</ExternalGraphic>
may I ask you were rail7.png is located? I guess the streaming renderer would try to locate the
file in the same folder geoserver is running since no real path is provided.
Andrea Aime
Example:
<ExternalGraphic>
</ExternalGraphic>
Andrea Aime
Hi Andrea,
rail7.png is located in the same directory that all SLDs are (styles folder).
Relative path (./rail7.png) didn't work so far.
I tried using a complete URL (the question mark gif in the Confluence example) and again, it didn't work. :frowning:
It works with Geoserver 1.3.0, instead. So I think it is not a problem in the SLD file (Have Geoserver 1.3.4 changed something in the SLD behavior?).
Frankly, I don't know... Haven't had time to reproduce it, will have a look at it tomorrow if nobody else has (it's lunch time here in Europe :slight_smile: )
Where is the png file located?
I just tested it with 1.3.4 and it works. I have the png file under my data_dir/styles directory.
Here is the snippit that I use in the SLD:
<PolygonSymbolizer>
                        <Fill>
                            <GraphicFill>
                                <Graphic>
                                    <ExternalGraphic>
                                        <OnlineResource xlink:type="simple" xlink:href="grass_fill.png"/>
                                    </ExternalGraphic>
                                    <Opacity>
                                        <ogc:Literal>1.0</ogc:Literal>
                                    </Opacity>
                                    <Size>
                                        <ogc:Literal>30</ogc:Literal>
                                    </Size>
                                    <Rotation>
                                        <ogc:Literal>0.5</ogc:Literal>
                                    </Rotation>
                                </Graphic>
                            </GraphicFill>
                        </Fill>
                        <Stroke>
                            <CssParameter name="stroke">#FF0000</CssParameter>
                            <CssParameter name="stroke-width">1</CssParameter>
                        </Stroke>
                    </PolygonSymbolizer>
Brent Owens
(The Open Planning Project)
Please,
Eduardo
Hi list,
Example:
<ExternalGraphic>
</ExternalGraphic>
Eduardo
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-users mailing list
Hi Brent,
Like I told Andrea Aime (thanks Andrea), my png file is in the same data_dir/styles directory.
And I have tested all possibilities (external URL, relative path, etc.)
The only difference to your test is that I used a <GraphicStroke> instead of <GraphicFill>. I presume that this is not the cause, but...
It could be something related to the war distribution? I also have Geoserver 1.3.0 war deployed, with <ExternalGraphic> working fine.
I will test this snippet you have just sent to me.
Thanks.
Eduardo Escovar
Brent Owens escreveu:
<PolygonSymbolizer>
                       <Fill>
                           <GraphicFill>
                               <Graphic>
                                   <ExternalGraphic>
                                   </ExternalGraphic>
                                   <Opacity>
                                   </Opacity>
                                   <Size>
                                   </Size>
                                   <Rotation>
                                   </Rotation>
                               </Graphic>
                           </GraphicFill>
                       </Fill>
                       <Stroke>
                       </Stroke>
Brent Owens
Please,
Eduardo
Hi list,
Example:
<ExternalGraphic>
</ExternalGraphic>
Eduardo
