a question not strictly related to GeoServer (sorry). It's about SLD
filtering:
I have all the point data in a postGIS table. I want to show only data of a
certain userID.
Then, I want the user to dynamically classify this data by different genus
(allways keeping in mind that only the userID data must be shown).
I thought that something like this should work:
<Filter>
<AND>
<PropertyIsEqualTo>
<PropertyName>userID</PropertyName>
<Literal>ID of the user</Literal>
</PropertyIsEqualTo>
<PropertyIsEqualTo>
<PropertyName>genus</PropertyName>
<Literal>ciconia</Literal>
<PropertyIsEqualTo>
<Literal>copris</Literal>
</AND>
</Filter>
( this Filter is inserted in the WebMap Context XML file and can be
manipulated by the user via AJAX/php )
But it doesn't work (it just doesn't show anything). It works if I only put
a <PropertyIsEqualTo> filter.
I've also tried to put an <OR> tag like this, but no success:
<Filter>
<AND>
<PropertyIsEqualTo>
<OR>
<PropertyIsEqualTo>
<PropertyIsEqualTo>
</OR>
</AND>
</Filter>
Some help?
thanks,
Pere Roca
Museo Nacional Ciencias Naturales
EDIT project (www.e-taxonomy.eu/)
http://edit.csic.es
View this message in context: http://www.nabble.com/SLD-filtering-question-tf4838350.html#a13842065
Pere,
The first filter will certainly not work. The second filter is what you
want, and should give results if the data is present. Try changing AND
to And, and OR to Or and see if you get different results (I think I've
had case sensitivity issues in the past in my SLDs).
John Fletcher
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of pere
roca
Sent: Monday, November 19, 2007 10:30 AM
Subject: [Geoserver-users] SLD filtering question
filtering:
of a certain userID.
genus (allways keeping in mind that only the userID data must be shown).
<Filter>
<AND>
<PropertyIsEqualTo>
<PropertyIsEqualTo>
<PropertyIsEqualTo>
</AND>
</Filter>
put a <PropertyIsEqualTo> filter.
<Filter>
<AND>
<PropertyIsEqualTo>
<OR>
<PropertyIsEqualTo>
<PropertyIsEqualTo>
</OR>
</AND>
</Filter>
Some help?
thanks,
Pere Roca
http://edit.csic.es
This SF.net email is sponsored by: Microsoft Defy all challenges.
Microsoft(R) Visual Studio 2005.
Geoserver-users mailing list
Verified. I just did a little test and changing from "AND" to "And" does
make the difference. Also, just so everything is above board you may
wish to try validating your sld document with the geoserver style
editor. These kinds of things will be caught by that.
-Justin
John Fletcher wrote:
Pere,
John Fletcher
roca
filtering:
<Filter>
<AND>
<PropertyIsEqualTo>
<PropertyIsEqualTo>
<PropertyIsEqualTo>
</AND>
</Filter>
<Filter>
<AND>
<PropertyIsEqualTo>
<OR>
<PropertyIsEqualTo>
<PropertyIsEqualTo>
</OR>
</AND>
</Filter>
Some help?
thanks,
Pere Roca
http://edit.csic.es
Defy all challenges. Microsoft(R) Visual Studio 2005.
!DSPAM:4007,4741e93624753327367457!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
yes, it’s true, it works now…
Thanks!
2007/11/19, Justin Deoliveira <jdeolive@anonymised.com>:
Verified. I just did a little test and changing from “AND” to “And” does
-Justin
Pere,
to And, and OR to Or and see if you get different results (I think I’ve
John Fletcher
[mailto:geoserver-users-bounces@lists.sourceforge.net ] On Behalf Of pere
roca
a question not strictly related to GeoServer (sorry). It’s about SLD
filtering:
userID
ID of the user
genus
ciconia
genus
copris
But it doesn’t work (it just doesn’t show anything). It works if I only
put a filter.
I’ve also tried to put an tag like this, but no success:
userID
ID of the user
genus
ciconia
genus
copris
Some help?
thanks,
Pere Roca
http://edit.csic.es
Justin Deoliveira
