[Geoserver-users] SLD font-sizes in points? [Sec=Unclassified]
> -----Original Message-----
> From: David E. Reksten
> When using an SLD, one can specify a font-size in pixels for
> the TextSymbolizer. This works fine for most webmapping applications.
> However, when I want to make a high resolution print of the
> same map, the labels end up too small, since the map
> requested might be something like 2000 by 1500 pixels in
> order to achieve the high resolution necessary in a PDF.
> [This more or less exact question was also asked by someone
> else in
> http://lists.eogeo.org/pipermail/wms-dev/2007-February/000894.html,
> but I was unable to find an answer]
> Does anyone have a solution for this problem?
> .david
David,
You could just make your map in Udig or similar, providing that you
don't need to have it's content generated on-the-fly. The drawback is
that you can't provide the generation of those maps as a web service,
but if you just wanted to create a few maps for yourself, it would suit
that purpose.
Regards
Miles
___________________________________________________________________________
    Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
        Visit our web site at http://www.antarctica.gov.au/
> else in
> .david
David,
that purpose.
Thanks, but we need the web service functionality in this case,
unfortunately. See also my response to Andrea on this issue.
.david
