Thanks Andrea,
I’ve requested an account. When I get it I’ll open a ticket.
I’ve added
vendorParams: {
buffer: 20 // geoserver buffer in pixels
to my WMSGetFeatureInfo control and now it is working great on my mobile device as well.
But can the buffer be scale depending, meaning can I set the pixels afterward?
I have a lot of points along a river, at low zoom levels the points are close to each other. Using the buffer selects sometimes the wrong point.
At higher zoom levels the points have more space between them, then the buffer is needed.
And I’m also still struggling with the SLD because when I create an extra rule using MinScale… to set uom=“http://www.opengeospatial.org/se/units/metre” only at higher zoom levels I also get an additional entry in my legend graphic.
I will do some more research, perhaps I need two separate layers each with their own SLD and group them together. But I have 4 layers and more will be added ;(
Paul
2013/8/28 Andrea Aime <andrea.aime@anonymised.com>
On Wed, Aug 28, 2013 at 8:49 AM, Paul Meems <bontepaarden@anonymised.com> wrote:
Thanks Andrea,
Adding uom=“http://www.opengeospatial.org/se/units/metre” to my PointSymbolizer is really improving the size of the point at higher zoom levels.
I’ll alter my sld to use pixel size on low zoom levels and meter size at higher zoom levels.
But the main problem for me is not solved. This might be a non-geoserver issue but more of an OpenLayers issue.
When I click on the point a pop-up needs to be shown using OpenLayers.Control.WMSGetFeatureInfo.
This works great using a desktop with a mouse, but on a mobile device it is very hard to select the point.
I’d hoped making the points bigger at higher zoom levels would improve this, but there’s no change.
Doh… I would have thought the same, but I see the GetFeatureInfo code is not taking into account the uom
rescaling. This is a bug, can you open a ticket on jira.codehaus.org?
About a workaround for you, you can try adding &buffer=n to your GetFeatureInfo request, where N is the
number of pixels you want to use as the search area
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
