[Geoserver-users] SLD grouping labels on a polygon
Im having some issues getting the label of a polygon in the expected place,
the centroid.
wheres one of my slds rules
      <PolygonSymbolizer>
        <Fill>
          <CssParameter name="fill">#d1d1d1 </CssParameter>
          <CssParameter name="fill-opacity">0.5</CssParameter>
        </Fill>
        <Stroke>
          <CssParameter name="stroke">#FFa850</CssParameter>
          <CssParameter name="stroke-width">1.5</CssParameter>
        </Stroke>
      </PolygonSymbolizer>
      <TextSymbolizer>
        <Label>
          <ogc:PropertyName>CODE</ogc:PropertyName>
        </Label>
          <CssParameter name="font-family">Arial</CssParameter>
          <CssParameter name="font-style">Normal</CssParameter>
          <CssParameter name="font-size">16</CssParameter>
        <Halo>
          <Radius>
            <ogc:Literal>2</ogc:Literal>
          </Radius>
          <Fill>
            <CssParameter name="fill">#FFFFFF</CssParameter>
            <CssParameter name="fill-opacity">0.85</CssParameter>
          </Fill>
        </Halo>
        <Fill>
          <CssParameter name="fill">#FFa850</CssParameter>
        </Fill>
      </TextSymbolizer>
with this i´m getting the label repeated all over the polygon.
also tried <VendorOption name="group">yes</VendorOption> or <VendorOption
name="group">true</VendorOption> at the end of <TextSymbolizer> but with no
results.
The funny thing is that if i put a pointsymbolizer, it is appearing in the
centroid of the polygon..
Can someone help?
Thanks in advance.
Pedro Mendes
View this message in context: http://www.nabble.com/SLD-grouping-labels-on-a-polygon-tp17623472p17623472.html
Hi Pedro. I've had luck with the spaceAround parameter in the past, which might be helpful in this case.
<VendorOption name="spaceAround"></VendorOption>
From digging around online, I found also this resource over at MassGIS:
http://lyceum.massgis.state.ma.us/wiki/doku.php?id=wms:sld:graphics_with_labels_inside
Hope this helps. Please let us know what you do to resolve your issue, as this tends to be a commonly asked question.
Mike Pumphrey
Outreach Engineer
The Open Planning Project
the centroid.
      <PolygonSymbolizer>
        <Fill>
        </Fill>
        <Stroke>
        </Stroke>
      <TextSymbolizer>
        <Label>
        </Label>
        <Halo> <Radius>
          </Radius>
          <Fill>
            <CssParameter name="fill-opacity">0.85</CssParameter> </Fill>
        </Halo>
        <Fill>
        </Fill>
      </TextSymbolizer>
results.
Can someone help?
Thanks in advance.
Pedro Mendes
results.
Can someone help?
Hum, are you using tiled rendering? GeoServer does not put multiple labels per polygon usually, there are two exceptions:
* multipolygons, each one of the polygons in a multipolygon gets
   labelled
* tiled rendering on the client side. If the polygon spans multiple
   tiles, each tile may have its own label. This is because each tile
   is a separate request, and GeoServer labels the portion of the
   polygon that falls into it.
   In this case you should look into metatiling, either by using
   the GeoServer built it mechanism
   (http://geoserver.org/display/GEOSDOC/WMS+vendor+parameters, see
   "on the fly meta tiler") or by using a tile cache such as GeoWebCache
   (that can be used as GeoServer plugin as well) or TileCache.
Sorry for late reply...
Yes, i´m using tiled rendering with TileCache. Geometries are multipolygons.
I did some tests requesting tiles with OpenLayers and the output was the
expected, meaning no duplicate labels.
Metatiling is set to true and metasize to 5. I regenerated cache for the
testing bounding box and the output was the expected.
p.s.: Must refer this about MetaTiling: i'm experiecing some failed
requested tiles when the metasize value is diferent of 1,1..
Thanks list, aaime
Cumps,Pedro
no
results.
the
Can someone help?
   labelled
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-users mailing list
View this message in context: http://www.nabble.com/SLD-grouping-labels-on-a-polygon-tp17623472p20974757.html
