Hi All,
I have an image mosaic that I can successfully use footprint management to
remove black space.
When I use a different style to change the band combination of the image,
the footprints are no longer being applied. Is there a known reason for
this? Has anybody had any experience modifying the SLD to help filter black
space.
I am reluctant to use 000000 as a transparent colour as we are using
satellite imagery that may genuinely contain a value of zero for the NIR
band.
Thoughts appreciated, SLD below
<Rule>
<RasterSymbolizer>
<Opacity>0.2</Opacity>
<ChannelSelection>
<RedChannel>
<SourceChannelName>3</SourceChannelName>
</RedChannel>
<GreenChannel>
<SourceChannelName>2</SourceChannelName>
</GreenChannel>
<BlueChannel>
<SourceChannelName>1</SourceChannelName>
</BlueChannel>
</ChannelSelection>
</RasterSymbolizer>
</Rule>
With standard Raster Style (supplied to us as BGR):
<http://osgeo-org.1560.x6.nabble.com/file/n5229677/image_footprint_BGR.png>
With new user generated style (Bands reordered to RGB):
<http://osgeo-org.1560.x6.nabble.com/file/n5229677/image_footprint_RGB.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-Image-Mosaic-and-Footprint-Management-tp5229677.html
Hi Gavin,
in 2.7.x there is basically no way to have channel selection and transparency at the moment.
In 2.8.x it might work, but completely untested I’m afraid, assuming you
do enable jai-ext. If you have a 2.8.x release try adding -Dorg.geotools.coverage.jaiext.enabled=true
as a startup parameter of the java virtual machine.
Let us know how that works
On Tue, Oct 13, 2015 at 12:36 PM, gavin.montgomery <gavin.montgomery@…3028…> wrote:
Hi All,
remove black space.
space.
band.
0.2
3
2
1
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
