Hi All,
In a SLD rule, I need to use a <TextSymbolizer> with both <Label> and <Graphic> elements (something similar to Highways Shields use case):
<Rule>
<TextSymbolizer>
<Label> ... </Label>
<Fill> ... </Fill>
<Halo> ... </Halo>
<Graphic><Mark><WellKnownName> ... </WellKnownName><Fill> ... </Fill></Mark> <Size> ... </Size></Graphic>
</TextSymbolizer>
</Rule>
This works well when the requirement is to get the same position X,Y for both Graphic and Label elements.
If I had well understood, the <LabelPlacement> element in such a rule would apply to both elements Label and Graphic.
Is it possible to define in such a rule a displacement which would only apply to the element Label?
Victor
This message is subject to and does not create or vary any contractual relationship between Campbell Scientific Limited, its subsidiaries or affiliates ("CSL") and you. Internet communications are not secure and therefore CSL does not accept legal responsibility for the contents of this message. The message is intended for the addressee only and its contents and any attached files are strictly confidential. If you have received it in error, please telephone +44 (0)1509 601141 or email postmaster@...7702... Thank you.
Campbell Scientific Ltd.
Company Registration Number: 1933935 (England and Wales) Registered Address: Campbell Park, 80 Hathern Road, Shepshed, Loughborough, Leicestershire LE12 9GX, UK
Tel: +44 (0) 1509 601141
Fax: +44 (0) 1509 601091
Web: www.campbellsci.co.uk
Hi Victor,
just split it into 2 rules: one for the graphic and one for the text label.
Then you can use different displacement in each of them.
Peter
On 25. 7. 2016 12:00, Victor.Sinceac wrote:
Hi All,
<Rule>
<TextSymbolizer>
<Fill> ... </Fill>
<Halo> ... </Halo>
</TextSymbolizer>
</Rule>
Victor
This message is subject to and does not create or vary any contractual relationship between Campbell Scientific Limited, its subsidiaries or affiliates ("CSL") and you. Internet communications are not secure and therefore CSL does not accept legal responsibility for the contents of this message. The message is intended for the addressee only and its contents and any attached files are strictly confidential. If you have received it in error, please telephone +44 (0)1509 601141 or email postmaster@anonymised.com Thank you.
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity planning
reports.http://sdm.link/zohodev2dev
Geoserver-users mailing list
Peter Kovac
IMS Programmer
MicroStep-MIS
peter.kovac@anonymised.com
