[Geoserver-users] SLD issue
Can anybody help me work out why my attached SLD doesn’t work.
I have two tables called ‘points’ and ‘polylines’ which are identical except for the type of the geometry column.
The second layer will not draw anything if the filter contains an ogc:And - you can see at the end of the attached file that I have commented everything out except for the session ID filter and this then works. I’ve tried the layers in the a different order and it makes no difference.
<<faulty.sld.txt>>
I’m using geoserver 1.4.0-RC3
Richard Shaw
¤º°°º¤ø,¸¸,ø¤º°°º¤ø¤º°°º¤ø,¸¸,ø¤º°°º¤ø¤º°`°º¤ø,¸¸,ø¤
Richard Shaw
Technical Design Authority - Information Solutions Consultancy
Intelligent Transport Systems
Atkins Highways and Transportation
Woodcote Grove, Ashley Road, Epsom, Surrey, KT18 5BW
Tel: +44 (0) 1372 756407
Fax: +44 (0) 1372 740055
Mob: 07740 817586
E-mail: richard.shaw@anonymised.com.1235…
www.atkinsglobal.com/its
This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding.
The ultimate parent company of the Atkins Group is WS Atkins plc. Registered in England No. 1885586. Registered Office Woodcote Grove, Ashley Road, Epsom, Surrey KT18 5BW.
faulty.sld.txt (37 KB)
On 7/10/07, Shaw, Richard A <richard.shaw@anonymised.com> wrote:
Can anybody help me work out why my attached SLD doesn't work.
I have two tables called 'points' and 'polylines' which are identical except
out except for the session ID filter and this then works. I've tried the
Its because
<ogc:And>
   <filter1>...</filter1>
   <filter2>...</filter2>
</ogc:And>
is legal and
<ogc:And>
   <filter3>....</filter3>
</ogc:And>
is not - you need to do
<ogc:And>
   <ogc:And>
   </ogc:And>
</ogc:And>
Ian
Ian Turton
http://www.geotools.org
http://pennspace.blogspot.com/
