Hi list,
According to the documentation [1] GeoServer labels each line only once. And if you want to repeat the label (for long lines) you should add the repeat vender option with a positive value (the number of pixels).
That’s not what I’m experiencing. In each of the following 3 scenarios I get the same image (with a repeated label):
Text symbolizer without repeat vender option
Text symbolizer with 150 (only in this scenario I would expect the label repetition)
Text symbolizer with -1
What am I missing here? I’m using a 2.5-SNAPSHOT (will upgrade to stable 2.5.1 later today).
[1] http://docs.geoserver.org/latest/en/user/styling/sld-reference/labeling.html#sld-reference-labeling
Kind regards,
Roel
For completeness the text symbolizer I’m using to test:
ogc:PropertyNamesoort_water</ogc:PropertyName>
#000000
true
90
400
Volg Aquafin op Facebook | Twitter | YouTube | LinkedIN
Disclaimer: zie www.aquafin.be P Denk aan het milieu. Druk deze mail niet onnodig af.
