[Geoserver-users] SLD: open arrow on center of end segment?
I’m using GeoServer 2.3.3 and I created a point symbolyzer which puts an open arrow on the end point of a line. This works great and is lightning fast. But I wonder if it’s somehow possible to put the arrow at the center of the end segment instead of the end point? Even better (for our use case) would be to put the arrow in the center of the central segment (with the correct rotation), but that’s just a nice to have. I would be more than happy with the center of the end segment.
In an attempt to get an arrow in the center of the line, I started playing with using an arrow symbol as a label. With a little bit of googling I ended up with the text symbolizer at the bottom which puts the arrow exactly where I want it to be. But my concern is what about the orientation of the arrow? Our lines have a direction: every geometry goes from start point to end point. I think labeling doesn’t care about it. Its main concern is putting the label along the line. Can I make sure the labels get oriented based on the direction of each line?
My text symbolizer:
ogc:Literal→</ogc:Literal>
Lucida Sans
18
normal
bold
-2
#000000
true
400
150
Volg Aquafin op Facebook | Twitter | YouTube | LinkedIN
Disclaimer: zie www.aquafin.be P Denk aan het milieu. Druk deze mail niet onnodig af.
Hi Roel,
I suspect using the “forcelefttoright” parameter at false may do what you want:
<se:VendorOption name=“forceLeftToRight”>false</se:VendorOption>
This allows labels to be “upside down” on a line. In theory at least (I don’t know how the labelling engine works), I’d imagine that’d ensure your arrow was pointing the right way.
Worth trying anyway. :slight_smile:
Jonathan
My text symbolizer:
Lucida Sans
18
normal
bold
-2
#000000
true
400
150
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Jonathan,
Thanks! That was the missing piece of the puzzle. Works like a charm!
Roel
Van: Jonathan Moules [mailto:jonathanmoules@anonymised.com]
Verzonden: dinsdag 16 juli 2013 17:43
Aan: Roel De Nijs
CC: geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] SLD: open arrow on center of end segment?
Hi Roel,
Jonathan
My text symbolizer:
Lucida Sans
18
normal
bold
-2
#000000
true
400
150
