[Geoserver-users] Sld Point Size based on zoom level
Hi All,
I am trying to create a Style that resize the Points according to Zoom level.
The problem is that the circle size isn´t changing, what i am doing wrong?
Ps: I don´t want to use the MaxScaleDenominator because i don’t want to re-write each rule just for changing the scaleDenominator.
My featureStyle is the following:
Geometry [Point]
rule1
Red Circle Simple Point circle #FF0000 wms_scale_denominator 3000000 2 1
Thanks.
Hi Danilo,
we are using a python script to generate SLDs that fit those needs
(generating a big sld using many rules of course). If you find abetter
way let me know.
Marco
Am 16.10.2014 um 21:26 schrieb Danilo da Silveira Figueira:
Hi All,
level.
Ps: I don´t want to use the MaxScaleDenominator because i don't want
<FeatureTypeStyle>
        <Name>Geometry [Point]</Name>
        <Rule>
          <Name>rule1</Name>
          <Title>Red Circle</Title>
          <Abstract>Simple Point</Abstract>
            <PointSymbolizer>
              <Graphic>
                <Mark>
                  <WellKnownName>circle</WellKnownName>
                  <Fill>
                    <CssParameter name="fill">#FF0000</CssParameter>
                  </Fill>
                </Mark>
              <Size>
                <ogc:Function name="if_then_else">
                  <ogc:Function name="lessEqualThan">
                     <ogc:Function name="env">
                      <ogc:Literal>wms_scale_denominator</ogc:Literal>
                    </ogc:Function>
                    <ogc:Literal>3000000</ogc:Literal>
                  </ogc:Function>
                  <ogc:Literal>2</ogc:Literal>
                  <ogc:Literal>1</ogc:Literal>
                </ogc:Function>
              </Size>
            </Graphic>
          </PointSymbolizer>
        </Rule>
      </FeatureTypeStyle>
Thanks.
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
Best Open Source Mac Front-Ends 2024
Geoserver-users mailing list
Thanks Russell!
The result was very interesting, exactly what i was searching for! =)
I suspect you need to set the units of measure so the point is always for example, 10 meters across.
Something like
https://wiki.state.ma.us/confluence/display/massgis/GeoServer±+SLD±+Units+of+Measure
2014-10-16 17:59 GMT-03:00 Danilo da Silveira Figueira <danilomalzao@anonymised.com>:
2014-10-16 17:58 GMT-03:00 Danilo da Silveira Figueira <danilomalzao@anonymised.com>:
Thanks Russell!
2014-10-16 16:41 GMT-03:00 Russell Hore (Amazon) <amazon.uk@anonymised.com>:
Something like
uom="http://www.opengeospatial.org/se/units/metre
Russ
On 16 Oct 2014, at 20:26, Danilo da Silveira Figueira <danilomalzao@anonymised.com> wrote:
Hi All,
Geometry [Point]
rule1
Thanks.
http://p.sf.net/sfu/Zoho_______________________________________________
Just completing the answer,
To use the ‘wms_scale_denominator’ parameter you have to use the parseDouble function, because for some reason i guess that the result of wms_scale_dominator is interpreted as string.
So the below style will work: ( The color of the points will change when the zoom level is above 7 )
circle wms_scale_denominator 8735660 #008080 #00FF00 2
2014-10-16 18:06 GMT-03:00 Russell Hore (Amazon) <amazon.uk@anonymised.com>:
Sorry, I posted this direct, now to theist.
Something like
Russ
Hi All,
Geometry [Point]
rule1
Thanks.
