[Geoserver-users] SLD problem with attribute filtering
Hello,
I have a SLD file styling 2 different shapefiles, one containing point and
the other containing polygons. The polygons have an attribute that the point
doesn't.
The problem is, that when I filter the Polygon in SLD on their attribute,
the point can't render because it doesn't have this attribute. Even if it
not under the same rule.
I hope I'm explaining well enough.
Please see the SLD and shapefiles attached as example.
Assign the SLD file to style the shapefiles, and see that the Area shapefile
is rendered correctly, but the Point shapefile can't render. If you remove
the filter for the attribute in the Polygon rule, then the point can render.
Thank you
test.zip <http://osgeo-org.1560.x6.nabble.com/file/n5252667/test.zip&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-problem-with-attribute-filtering-tp5252667.html
Why not create two different SLDs?
On Wed, Feb 24, 2016 at 3:41 PM, Geoffrey <balmeg@anonymised.com> wrote:
Hello,
doesn’t.
the point can’t render because it doesn’t have this attribute. Even if it
I hope I’m explaining well enough.
is rendered correctly, but the Point shapefile can’t render. If you remove
Thank you
​I need to have everything in 1 SLD., it’s a part of the requirements of the work I have to do.
Isn’t this behavior a bug of geoserver ? It shouldn’t behave this way when you don’t have the exact same attribute for your point and your polygon.
2016-02-25 2:06 GMT+01:00 Martin Davis <mtnclimb@anonymised.com>:
Hello,
doesn’t.
Thank you
Just a guess, but this is probably caused by a pre-scan that GeoServer does to validate that all the attributes referred to in the SLD are available in the underlying layer. (One reason for this I think is that GeoServer only requests the attributes needed to compute the SLD filters).
I’m not sure this can be called a bug, it’s more of a design limitation. And as such you may have to adjust your requirements to match the tool you are using…
On Wed, Feb 24, 2016 at 5:10 PM, Geoffrey Balme <balmeg@anonymised.com> wrote:
On Wed, Feb 24, 2016 at 3:41 PM, Geoffrey <balmeg@anonymised.com.> wrote:
Hello,
doesn’t.
Thank you
I agree with Martin, separate styles would be better and much more maintainable.
However, if you really need to have you tried filtering by geometry type on the rule, e.g.
ogc:PropertyIsEqualTo
ogc:PropertyNamegtype</ogc:PropertyName>
ogc:LiteralPoint</ogc:Literal>
</ogc:PropertyIsEqualTo>
Or maybe basing the layers on views which make the layers look the same at an attribute level (i.e. add columns with null/default values for missing attributes).
2016-02-25 2:06 GMT+01:00 Martin Davis <mtnclimb@…84…>:
On Wed, Feb 24, 2016 at 3:41 PM, Geoffrey <balmeg@…84…> wrote:
Hello,
doesn’t.
Thank you
On Thu, Feb 25, 2016 at 2:17 AM, Martin Davis <mtnclimb@anonymised.com> wrote:
We actually do that because back at the time, we had a lot of complaints by
users that styles were not working
and upon inspection, they contained typos in the attribute names. That
wasted a lot of time on the list.
I'm not sure this can be called a bug, it's more of a design limitation.
are using...
It's a design decision. If someone wants to do the work, I would not be
opposed to make the attribute check controlled
by a flag (system variable of sorts), so that it can be disabled
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I’ve been looking into this this week for my own work.
I note in the OGC Filters specification 2.0 (http://docs.opengeospatial.org/is/09-026r2/09-026r2.html) the following definition for the PropertyIsNull operator:
“The PropertyIsNull operator tests the specified property to see if it exists in the resource being evaluated. This corresponds to checking whether the property exists in the real-world”
This is in contrast to the OGC Filters 1.0 spec which for the same filter says:
“The element encodes an operator that checks to see if the value of its content is NULL. A NULL is equivalent to no value present. The value 0 is a valid value and is not considered NULL.”
So I guess if GeoServer switches to Filters 2.0, you’ll be able to use the PropertyIsNull operator in conjuncton with AND/OR/NOT to build an expression. I just tried to do this with a 2.7.x install of Geoserver, but get the obligatory XML error returned: “The requested Style can not be used with this layer”
(the 2.0 spec also includes a section demonstrating how to create a “PropertyExists” filter; so someone clearly wanted this sort of functionality added to the spec).
Jonathan
---- On Thu, 25 Feb 2016 07:18:27 +0000 Andrea Aime andrea.aime@anonymised.com wrote ----
We actually do that because back at the time, we had a lot of complaints by users that styles were not working
and upon inspection, they contained typos in the attribute names. That wasted a lot of time on the list.
It’s a design decision. If someone wants to do the work, I would not be opposed to make the attribute check controlled
Ing. Andrea Aime
@geowolf
Technical Lead
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140_______________________________________________
Geoserver-users mailing list
On Mon, Feb 29, 2016 at 4:24 PM, Jonathan Moules <
jonathan-lists@anonymised.com> wrote:
So I guess if GeoServer switches to Filters 2.0, you'll be able to use the
get the obligatory XML error returned: "The requested Style can not be used
with this layer"
"PropertyExists" filter; so someone clearly wanted this sort of
GeoServer has nothing to switch to, we'd need a SLD 2.0 that uses Filter
2.0, but it's not out there afaik :slight_smile:
That said, we have a PropertyExists filter function, but the code that's
checking for property existence does not know what
that function does, so it won't make any difference.
Ing. Andrea Aime
@geowolf
Technical Lead
