[Geoserver-users] SLD Question : Dynamic rotation
Dear All ..
My in one table of my datasource (storage=PostGis, type=POINT), I have column called "bearing" with type "double precission".
I want to display the points wil simple WellKnownName "Arrow", but I want to rotate it dynamicaly based on the value of "bearing" column.
I Tried this in SLD:
                <Rotation>
                    <CssParameter name="rotation"><ogc:PropertyName>bearing</ogc:PropertyName></CssParameter>
                </Rotation>
Note : complete sld attached
The Geoserver SLD validator said it's not-valid with msg :
----BEGIN ERROR---
org.xml.sax.SAXParseException: cvc-complex-type.2.4.a: Invalid content was found starting with element 'CssParameter'. One of '{"http://www.opengis.net/ogc&quot;:expression\}' is expected.
----END ERROR---
How is the valid methode to do dynamic symbol rotation based on point attribute ?
Sincerely
-bino-
ttrack.xml (3.46 KB)
On Wed, Oct 13, 2010 at 6:57 AM, Bino Oetomo <bino@anonymised.com> wrote:
Dear All ..
<Rotation>
<CssParameter
</Rotation>
Rotation takes an expression not a CssParameter so
              <Rotation>
              </Rotation>
should work fine
See http://gridlock.openplans.org/geoserver/2.0.x/doc/en/user/styling/sld-cookbook/points.html#rotated-square
for more details.
Ian
Ian Turton
Hi Ian ..
              <Rotation>
              </Rotation>
should work fine
for more details.
Thankyou for your enlightment.
It work like a champ
-bino-
