Hello,
I’m not sure if I’m on the right path here or not or if something like this is possible but I was wondering if there was a way to inspect the Geometry property within a LineSymbolizer and then use it to offset the actual plotted value?
So basically if I was drawing a line then for each point in that line have it run through some SLD rule to offset it by some amount of x and y pixels? This would be useful if you wanted to try to maintain a perspective of a layer on a map as you zoomed in or out.
Thanks, S.D.
