[Geoserver-users] SLD - Raster problem
Hello,
I'm trying to execute the ras:StyleCoverage process from the WPS request
Builder.
I copy the SLD code of a raster image from Styles --> [raster image] and I
paste it
to the ras:StyleCoverage process' form.
I intergrate the sld code from the examples of the following link:
http://docs.geoserver.org/latest/en/user/styling/sld-cookbook/rasters.html
to the main code of the form.
But whenever I execute the process, GeoServer opens the image but with no
changes.
The processed image is exactly the same with the original image.
What do I do wrong ?
Greetings,
George
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-Raster-problem-tp5103936.html
Ciao Gpetr,
I would more information to help out with this problem.
  • a gdalinfo on the data
  • a sample style
  • version of geoserver
Generally speaking an isolate test-case with sample data would be much appreciated.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Sat, Feb 15, 2014 at 3:49 AM, Gpetr <gkpetrak@anonymised.com> wrote:
Hello,
I’m trying to execute the ras:StyleCoverage process from the WPS request
Builder.
I copy the SLD code of a raster image from Styles → [raster image] and I
paste it
to the ras:StyleCoverage process’ form.
changes.
Greetings,
George
Android apps run on BlackBerry 10
Introducing the new BlackBerry 10.2.1 Runtime for Android apps.
Now with support for Jelly Bean, Bluetooth, Mapview and more.
Get your Android app in front of a whole new audience. Start now.
http://pubads.g.doubleclick.net/gampad/clk?id=124407151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ciao Simone, thank you for your reply,
The version of GeoServer that I'm using is the 2.4-SNAPSHOT.
For the test I'm using a satellite image with red green and blue bands
(RGB).
The informations of the image from the gdalinfo command are:
Driver: GTiff/GeoTIFF
Files: L8_ms_30_04_13.tif
Size is 6375, 2820
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (22.234617285022399,38.179278213209521)
Pixel Size = (0.000306062103134,-0.000306062103134)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 22.2346173, 38.1792782) ( 22d14' 4.62"E, 38d10'45.40"N)
Lower Left ( 22.2346173, 37.3161831) ( 22d14' 4.62"E, 37d18'58.26"N)
Upper Right ( 24.1857632, 38.1792782) ( 24d11' 8.75"E, 38d10'45.40"N)
Lower Right ( 24.1857632, 37.3161831) ( 24d11' 8.75"E, 37d18'58.26"N)
Center ( 23.2101902, 37.7477306) ( 23d12'36.68"E, 37d44'51.83"N)
Band 1 Block=6375x1 Type=Byte, ColorInterp=Red
  Mask Flags: PER_DATASET ALPHA
Band 2 Block=6375x1 Type=Byte, ColorInterp=Green
Band 3 Block=6375x1 Type=Byte, ColorInterp=Blue
Band 4 Block=6375x1 Type=Byte, ColorInterp=Alpha
The SLD code from the Styles --> [Raster Image] is the following:
<sld:StyledLayerDescriptor xmlns="http://www.opengis.net/sld&quot;
xmlns:sld="http://www.opengis.net/sld&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot;
xmlns:gml="http://www.opengis.net/gml&quot; version="1.0.0">
  <sld:NamedLayer>
    <sld:Name>l8_ms_30_04_13</sld:Name>
    <sld:UserStyle>
      <sld:Title>l8_ms_30_04_13</sld:Title>
      <sld:FeatureTypeStyle>
        <sld:Name>name</sld:Name>
        <sld:Rule>
          <sld:RasterSymbolizer/>
        </sld:Rule>
      </sld:FeatureTypeStyle>
    </sld:UserStyle>
  </sld:NamedLayer>
</sld:StyledLayerDescriptor>
I intergrate the "Brightness and contrast" example from the following link:
http://docs.geoserver.org/stable/en/user/styling/sld-cookbook/rasters.html#brightness-and-contrast
The final code that I insert on the form, is the following:
  <sld:NamedLayer>
    <sld:UserStyle>
        <sld:Rule>
         <ContrastEnhancement>
           <Normalize />
           <GammaValue>0.5</GammaValue>
         </ContrastEnhancement>
         <ColorMap>
           <ColorMapEntry color="#008000" quantity="70" />
           <ColorMapEntry color="#663333" quantity="256" />
         </ColorMap>
        </sld:Rule>
    </sld:UserStyle>
  </sld:NamedLayer>
After the process, the problem remains the same.
How can fix it ?
Thank you again for your help,
George
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-Raster-problem-tp5103936p5104117.html
Ciao Gpetr,
please, read below…
Simone Giannecchini
@simogeo
Founder/Director
The version of GeoServer that I’m using is the 2.4-SNAPSHOT.
For the test I’m using a satellite image with red green and blue bands
(RGB).
Size is 6375, 2820
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]]
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 22.2346173, 38.1792782) ( 22d14’ 4.62"E, 38d10’45.40"N)
Lower Left ( 22.2346173, 37.3161831) ( 22d14’ 4.62"E, 37d18’58.26"N)
Upper Right ( 24.1857632, 38.1792782) ( 24d11’ 8.75"E, 38d10’45.40"N)
Lower Right ( 24.1857632, 37.3161831) ( 24d11’ 8.75"E, 37d18’58.26"N)
Center ( 23.2101902, 37.7477306) ( 23d12’36.68"E, 37d44’51.83"N)
The SLD code from the Styles → [Raster Image] is the following:
<sld:StyledLayerDescriptor xmlns=“http://www.opengis.net/sld
xmlns:sld=“http://www.opengis.net/sld
xmlns:ogc=“http://www.opengis.net/ogc
xmlns:gml=“http://www.opengis.net/gml” version=“1.0.0”>
sld:NamedLayer
sld:Namel8_ms_30_04_13</sld:Name>
sld:UserStyle
sld:Titlel8_ms_30_04_13</sld:Title>
sld:Namename</sld:Name>
sld:Rule
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
I intergrate the “Brightness and contrast” example from the following link:
sld:NamedLayer
sld:UserStyle
sld:Rule
0.5
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
This won’t work on your dataset. You are trying to apply a colormap to a 4 band image, it does not make sense.
I would do this:
  • select 3 bands out of 4, removing the alpha (assuming it is an alpha)
  • aply the contrast enhancement on each single band (or gloablly)
Check the following links:
http://docs.geoserver.org/stable/en/user/styling/sld-reference/rastersymbolizer.html
http://docs.codehaus.org/display/GEOTOOLS/Raster+Symbolizer+support
How can fix it ?
George
Hello Simone, thanks for you helpful reply,
You 're right the RGB images have another Alpha band ?
I tried some more processes specifying the bands (red, green, blue) but
nothing change.
The following code is one of my tests:
  <sld:NamedLayer>
    <sld:UserStyle>
        <sld:Rule>
          <Opacity>0.5</Opacity>
          <ChannelSelection>
          <RedChannel>
          <SourceChannelName>4</SourceChannelName>
         </RedChannel>
         <GreenChannel>
        <SourceChannelName>3</SourceChannelName> >
        </GreenChannel>
         <BlueChannel>
         <SourceChannelName>2</SourceChannelName>
         </BlueChannel>
         </ChannelSelection>
        </sld:Rule>
    </sld:UserStyle>
  </sld:NamedLayer>
What do I do wrong ? Is needed to remove the Alpha band ? and how can I do
it from GeoServer ?
Thank you in advace,
George
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-Raster-problem-tp5103936p5104591.html
Ciao Gpetr,
can you send a sample, even privately?
Simone Giannecchini
@simogeo
Founder/Director
nothing change.
sld:NamedLayer
sld:UserStyle
sld:Rule
0.5
4
3 >
2
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
it from GeoServer ?
George
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
