Color variable substitution works only when there is ONE SINGLE RULE in the SLD; when the SLD contains 2 or more rules, the variable substitution is broken and default color values are always used.
It is reproducible on any raster layer in GeoServer 2.8.3/2.9.0.
Did someone found a workaround to this issue?
Here below a minimalist SLD (for DEM geotiff layer) with 2 similar rules with reversed default colors. The filter allows the client to explicitly call the 1st rule by using "ENV=rule:1".
A WMS GetMap query with a different color value for a color (e.g. "ENV=rule:1;c1:%230000FF”, i.e. Blue instead default Read) returns as follows:
- NOK: the default (Red) color when the SLD contain 2 rules
- OK: the ENV value (Blue) color send in the query if the SLD only contains the 1st rule (i.e. the 2nd is manually removed from the SLD)
<Rule><Name>Red_Water</Name>
<ogc:Filter><ogc:PropertyIsEqualTo><ogc:Literal>1</ogc:Literal><ogc:Function name="env"><ogc:Literal>rule</ogc:Literal></ogc:Function></ogc:PropertyIsEqualTo></ogc:Filter>
<RasterSymbolizer><Opacity>1.0</Opacity><ChannelSelection><GrayChannel><SourceChannelName>1</SourceChannelName></GrayChannel></ChannelSelection>
<ColorMap type="intervals"><ColorMapEntry color= "${env('c1','#FF0000')}" quantity= "10"/><ColorMapEntry color= "${env('c2','#000000')}" quantity= "9000"/></ColorMap>
</RasterSymbolizer>
</Rule>
<Rule><Name>Black_Water</Name><ogc:Filter><ogc:PropertyIsEqualTo><ogc:Literal>2</ogc:Literal><ogc:Function name="env"><ogc:Literal>rule</ogc:Literal></ogc:Function></ogc:PropertyIsEqualTo></ogc:Filter>
<ColorMap type="intervals"><ColorMapEntry color= "${env('c1','#000000')}" quantity= "10"/> <ColorMapEntry color= "${env('c2','#FF0000')}" quantity= "9000"/></ColorMap>
</RasterSymbolizer>
</Rule>
Many Thanks,
Victor
This message is subject to and does not create or vary any contractual relationship between Campbell Scientific Limited, its subsidiaries or affiliates ("CSL") and you. Internet communications are not secure and therefore CSL does not accept legal responsibility for the contents of this message. The message is intended for the addressee only and its contents and any attached files are strictly confidential. If you have received it in error, please telephone +44 (0)1509 601141 or email postmaster@...7702... Thank you.
Campbell Scientific Ltd.
Company Registration Number: 1933935 (England and Wales) Registered Address: Campbell Park, 80 Hathern Road, Shepshed, Loughborough, Leicestershire LE12 9GX, UK
Tel: +44 (0) 1509 601141
Fax: +44 (0) 1509 601091
Web: www.campbellsci.co.uk
