[Geoserver-users] SLD Rest Service
Hello,
Looking for more examples and documentation about how to properly use the SLD Rest Service.
I have read through the documentation for the service here (http://docs.geoserver.org/stable/en/user/community/sldservice/index.html)
The documentation shows that there should be a path in the API /rest/sldservice/. However, when I look at the REST API directory I don’t see the sldservice path.
Therefore I am can not get the attributes of my layers, using the example http://localhost:8080/geoserver/rest/sldservice//attributes.xml
Are there other extensions that need to be loaded to fully utilize the SLD REST Service?
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
www.terrapop.org
On Tue, Aug 11, 2015 at 4:16 PM, David Haynes II <dahaynes@anonymised.com> wrote:
Hello,
SLD Rest Service.
/rest/sldservice/<layer>. However, when I look at the REST API directory I
don't see the sldservice path.
The SLD service is a community extension, did you go and install it first?
:slight_smile:
E.g, if you are using a 2.7.x series, you can get it from there:
http://ares.boundlessgeo.com/geoserver/2.7.x/community-latest/
No promises it will work, community modules are not supported :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi David,
please stay on the list.
On Tue, Aug 11, 2015 at 6:12 PM, David Haynes II <dahaynes@anonymised.com> wrote:
Hello,
There is no readme file. How do I know if I have installed it properly. I placed the jar files in the webapps\geoserver\web-inf\lib directory.
Hum… I would not know, never installed it, but normally all you have to do is indeed to expand
the jar files where you already put them, and restart GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
