[Geoserver-users] SLD Rest Service
Hello,
Has anyone successfully implemented the community tool SLD Rest Service? I downloaded and placed it within the lib folder, but the sldrest directory does not exist.
Any help would be appreciated.
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
www.terrapop.org
On Thu, Aug 13, 2015 at 4:25 PM, David Haynes II <dahaynes@anonymised.com> wrote:
Hello,
does not exist.
I know that a colleague of mine worked on it a bit, but it was like 9
months ago, and I'm not sure
along which version of GeoServer it was tested.
I've cc'ed him, but he's in vacation and won't be back before the end of
August
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hello,
Andrea mentioned that you have been able to get the community extension SLD REST Service to work. Is this true. The zip file doesn’t contain any readme information and inside are two jar files: xom and gs-sldservice SNAPSHOT. I placed both within the web-inf\lib directory. So far I there are no additional options regarding the REST service.
I thought I would ask before investigating the jar file and making a mess.
On Thu, Aug 13, 2015 at 9:38 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hello,
I know that a colleague of mine worked on it a bit, but it was like 9 months ago, and I’m not sure
I’ve cc’ed him, but he’s in vacation and won’t be back before the end of August
Ing. Andrea Aime
@geowolf
Technical Lead
David Haynes, Ph.D.
www.terrapop.org
