[Geoserver-users] SLD strMatches problem
I'm not sure if this is the right place to as.
I tried to create a style using a regex to match the values in a postgis table.
I wrote the following:
<ogc:PropertyIsEqualTo>
  <ogc:Function name="strMatches">
   <ogc:PropertyName>tags</ogc:PropertyName>
     <ogc:Literal>\b(15|3|8)\b</ogc:Literal>
   </ogc:Function>
  <ogc:Literal>true</ogc:Literal>
</ogc:PropertyIsEqualTo>
The field "tags" is a varchar and the values in it are integers separated by a comma:
6,4
8,16,3
42,15
9
If one of the numbers matches 15, 3 or 8 the function should return true.
The regex works on a test site but it doesn't work on my sld.
I'm don't know if the regex is managed by geoserver/java or is passed to postgis/posgresql.
In postgresql \b is not used, I had to use another expression in a query.
Any help?
thank you
   maxx
Hi Emmex,
filter functions are generally not translated down in SQL.
Postgis is actually the one exception that has a handful of sample
functions translated to sql, but strMatches is not one of them.
Even if there was this ability, you’d still have to specify the
matching pattern using the Java Pattern syntax, and the
SQL translator would have to turn it into the native one instead
On Sat, Nov 1, 2014 at 1:02 PM, emmexx <emmexx@anonymised.com749…> wrote:
I’m not sure if this is the right place to as.
table.
<ogc:Function name=“strMatches”>
ogc:PropertyNametags</ogc:PropertyName>
ogc:Literal\b(15|3|8)\b</ogc:Literal>
</ogc:Function>
ogc:Literaltrue</ogc:Literal>
The field “tags” is a varchar and the values in it are integers
6,4
8,16,3
42,15
9
The regex works on a test site but it doesn’t work on my sld.
I’m don’t know if the regex is managed by geoserver/java or is passed to
postgis/posgresql.
Any help?
thank you
maxx
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Il 11/01/2014 02:01 PM, Andrea Aime scrisse:
Even if there was this ability, you'd still have to specify the
Thank you Andrea,
from what I read (google, forums, javadoc) the syntax \b(15|3|8)\b seems to be right.
http://docs.oracle.com/javase/6/docs/api/java/util/regex/Pattern.html
\b A word boundary
X|Y Either X or Y
(X) X, as a capturing group
Is there some problem with character encodings? Should I specify other parameters?
bye
  maxx
Thank you Andrea,
to be right.
\b A word boundary
X|Y Either X or Y
Hum... I believe strMatch matches the whole string, so you should add .*
before and after your pattern:
     <ogc:Literal>.*\b(15|3|8)\b.*</ogc:Literal>
   </ogc:Function>
Ing. Andrea Aime
@geowolf
Technical Lead
Il 11/01/2014 02:40 PM, Andrea Aime scrisse:
That's it!
Thank you
  maxx
