[Geoserver-users] SLD - stroke-dashoffset in both ends
Hi list,
I have not found any way to style a line in a way that it is not visible for
some length i both ends. Have you?
<CssParameter name="stroke-dashoffset">60</CssParameter> will start drawing
the line 60 px from the starting point, but how should i do the same in the
endpoint?
regards, Jakob
View this message in context: http://osgeo-org.1560.x6.nabble.com/SLD-stroke-dashoffset-in-both-ends-tp5105801.html
On Tue, Feb 25, 2014 at 1:00 PM, Jakob Ventin <jventin@anonymised.com> wrote:
Hi list,
for
I don't believe SLD offers any immediate way... but I can think of a slow
one
that might work using existing GeoServer extensions
endpoint?
Actually, the dashoffset just changes the starting point for the dashoffset
pattern,
so it cannot be replicated on the other side.
One thing that might work if your lines are mostly straight, but it's
somewhat complicated and inefficient,
is to extract the two end points, buffer them, and then perform a
difference,
using the many filter functions provided by GeoServer:
http://docs.geoserver.org/stable/en/user/filter/function_reference.html
See some examples here:
http://docs.geoserver.org/stable/en/user/styling/sld-extensions/geometry-transformations.html
That said, it would be better to write a custom filter function to shorten
a line instead, which
would require some java programming. I think it's also possible to write
filter functions
using a scripting language with the geoscript hooks, but I can't find
documentation
on how to do that. Maybe Justin (cc'ed) has some pointers
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
