[Geoserver-users] SLD Styler doesn't save styles
Hi together
I tried to edit my sld with the stylerplugin and it worked fine until I
restarted my tomcat. Afterwards there were the old ones. Does anyone know
what is the problem and probably a solution?
Thank you
Fabio Renggli
Hi Fabio,
Yes, this is a known issue, described here:
http://jira.codehaus.org/browse/GEOS-2825
It has since been fixed, so if you grab a recent nightly build it should work as expected.
http://gridlock.openplans.org/geoserver/1.7.x/geoserver-1.7.x-latest-bin.zip
http://gridlock.openplans.org/geoserver/1.7.x/ext-latest/geoserver-1.7.3-SNAPSHOT-restconfig-plugin.zip
-Justin
Fabio Renggli wrote:
Hi together
Thank you
Fabio Renggli
Stay on top of everything new and different, both inside and around Java (TM) technology - register by April 22, and save
$200 on the JavaOne (SM) conference, June 2-5, 2009, San Francisco.
300 plus technical and hands-on sessions. Register today. Use priority code J9JMT32. http://p.sf.net/sfu/p
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
