[Geoserver-users] SLD styling for negative values
Dear list,
sorry for cross-posting (see also: http://tinyurl.com/nwxvew6) but I am stuck. I am trying to style negative values in Geoserver via SLD and would like to know how the syntax in SLD should look like to do this. What I have is the following:
—snip—
<?xml version="1.0" encoding="UTF-8"?> trnsfrm_meta_outputmap trnsfrm_meta_outputmap -0.8290 - -0.4632 -0.8290 - -0.4632 percentage_change -0.828977 percentage_change -0.463182 #0000ff #000000 0.26 bevel ---snip---
But this throws an error in Geoserver:
Caused by: org.postgresql.util.PSQLException: ERROR: invalid input syntax for type numeric: "-"
    Position: 406
I already tried to change the SLD from this
ogc:Literal-ogc:Literal0.828977</ogc:Literal></ogc:Literal>
to this:
ogc:Literal-0.828977</ogc:Literal>
But this doesn’t work either (Geoserver tells me that my SLD is not valid). I also reduced the number of rows in the PostGIS table to one and tried positive and negative values for the respective field, the error is always the same so I suspect a problem with the SLD.
So my question is: What is the correct way of styling negative values in SLD? Or do I have to look for something else that I have not thougt of so far?
Thanks in advance an best regards
Jan
On Thu, Sep 4, 2014 at 10:46 AM, Jan Peters <petersjan@anonymised.com> wrote:
to this:
<ogc:Literal>-0.828977</ogc:Literal>
But this doesn't work either (Geoserver tells me that my SLD is not
This one is the correct way. What's the error you're getting? It probably
has nothing to do with the minus sign...
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Thu, Sep 4, 2014 at 10:57 AM, Andrea Aime <andrea.aime@anonymised.com>
to this:
Wait, this is certainly wrong:
<ogc:Literal>-<ogc:Literal>0.828977</ogc:Literal>
            </ogc:Literal>
Two nested literals? It should be simply be:
<ogc:PropertyIsLessThanOrEqualTo>
            <ogc:PropertyName>percentage_change</ogc:PropertyName>
            <ogc:Literal>-0.463182</ogc:Literal>
          </ogc:PropertyIsLessThanOrEqualTo>
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Sep 4, 2014 at 11:06 AM, Jan Peters <petersjan@anonymised.com> wrote:
Well, the double nested Literals is what QGis created automatically.
Eh, I would not trust QGis to generate SLDs GeoServer can interpret (and in
this case, not even valid SLDs at all,
regardless of what GeoServer can grok).
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Sep 4, 2014 at 11:12 AM, Jan Peters <petersjan@anonymised.com> wrote:
Ok, I won't tust it. What is the most trustable software to create SLDs
btw?
uDig, generates valid SLD 1.0 files that also have GeoServer own extensions
to the SLD syntax
(instead of QGis, which does SLD 1.1, sometimes invalid, and with its own
sytanx extensions that
GeoServer does not understand)
It would be nice if someone sponsored some days of development so that our
code learns to
parse QGis own extras, but this hasn't happened yet...
Ing. Andrea Aime
@geowolf
Technical Lead
Jan, could you please keep the mailing list cc’ed?
About the error, try enabling “verbose logging” and then
see what the sql query being generated is.
On Thu, Sep 4, 2014 at 11:16 AM, Jan Peters <petersjan@anonymised.com> wrote:
Well, I now tried this SLD (Geoserver validated it now):
ogc:PropertyNamepercentage_change</ogc:PropertyName>
</ogc:PropertyIsGreaterThan>
ogc:Literal-0.463182</ogc:Literal>
</ogc:And>
</ogc:Filter>
se:PolygonSymbolizer
se:Fill
<se:SvgParameter name=“fill”>#0000ff</se:SvgParameter>
</se:Fill>
se:Stroke
<se:SvgParameter name=“stroke”>#000000</se:SvgParameter>
<se:SvgParameter name=“stroke-width”>0.26</se:SvgParameter>
<se:SvgParameter name=“stroke-linejoin”>bevel</se:SvgParameter>
</se:Stroke>
</se:PolygonSymbolizer>
</se:Rule>
se:Rule
se:Name-0.4632 - -0.0974</se:Name>
se:Description
se:Title-0.4632 - -0.0974</se:Title>
</se:Description>
<ogc:Filter xmlns:ogc=“http://www.opengis.net/ogc”>
ogc:And
ogc:Literal-ogc:Literal0.0973864</ogc:Literal>
</ogc:Literal>
</ogc:And>
</ogc:Filter>
se:Fill
<se:SvgParameter name=“fill”>#7f7f7f</se:SvgParameter>
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Name-0.0974 - 0.2684</se:Name>
se:Description
se:Title-0.0974 - 0.2684</se:Title>
</se:Description>
ogc:And
ogc:Literal-0.0973864</ogc:Literal>
ogc:Literal0.268409</ogc:Literal>
</ogc:And>
</ogc:Filter>
se:Fill
<se:SvgParameter name=“fill”>#ffff00</se:SvgParameter>
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Name0.2684 - 0.6342</se:Name>
se:Description
se:Title0.2684 - 0.6342</se:Title>
</se:Description>
ogc:And
ogc:Literal0.634205</ogc:Literal>
</ogc:And>
</ogc:Filter>
se:Fill
<se:SvgParameter name=“fill”>#ff7f00</se:SvgParameter>
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Name0.6342 - 1.0000</se:Name>
se:Description
se:Title0.6342 - 1.0000</se:Title>
</se:Description>
ogc:And
ogc:Literal1</ogc:Literal>
</ogc:And>
</ogc:Filter>
se:Fill
<se:SvgParameter name=“fill”>#ff0000</se:SvgParameter>
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
</se:FeatureTypeStyle>
and still got this error:
04 Sep 10:10:15 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Rendering process failed
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:507)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:251)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:123)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:521)
at org.geoserver.wms.GetMap.run(GetMap.java:253)
at org.geoserver.wms.GetMap.run(GetMap.java:124)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:328)
at sun.reflect.GeneratedMethodAccessor985.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:61)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:35)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:79)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:54)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy764.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor944.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:200)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
Caused by: java.lang.RuntimeException: java.io.IOException
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:168)
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:59)
at org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer.java:2475)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2045)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:829)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:481)
… 110 more
Caused by: java.io.IOException
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:610)
at org.geotools.jdbc.JDBCFeatureStore.getReaderInternal(JDBCFeatureStore.java:225)
at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:563)
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:165)
… 115 more
Caused by: org.postgresql.util.PSQLException: ERROR: invalid input syntax for type double precision: “-”
Position: 501
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1795)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:479)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:353)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:252)
at org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at org.geotools.jdbc.JDBCFeatureReader.(JDBCFeatureReader.java:140)
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:580)
… 118 more
the structure of my PostGIS table is:
CREATE TABLE “public”.“trnsfrm_meta_outputmap_jan” (
“scenarioname” varchar COLLATE “default” NOT NULL,
“sequencename” varchar COLLATE “default” NOT NULL,
“kpiname” varchar COLLATE “default” NOT NULL,
“timestamp” date NOT NULL,
“fuel” varchar COLLATE “default” NOT NULL,
“value” float8 NOT NULL,
“the_geom” “public”.“geometry” NOT NULL,
“pk” int4 DEFAULT nextval(‘trnsfrm_meta_outputmap_copy1_pk_seq’::regclass) NOT NULL,
“percentage_change” float8,
“percentage_change_numeric” numeric(8,4),
CONSTRAINT “trnsfrm_meta_outputmap_copy1_pkey1” PRIMARY KEY (“pk”)
WITH (OIDS=FALSE)
Gesendet: Donnerstag, 04. September 2014 um 11:10 Uhr
Von: “Andrea Aime” <andrea.aime@anonymised.com>
An: “Jan Peters” <petersjan@anonymised.com>, “GeoServer Mailing List List” <geoserver-users@lists.sourceforge.net>
Betreff: Re: Re: [Geoserver-users] SLD styling for negative values
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Sep 4, 2014 at 11:06 AM, Jan Peters <petersjan@anonymised.com.131…> wrote:
Eh, I would not trust QGis to generate SLDs GeoServer can interpret (and in this case, not even valid SLDs at all,
Ing. Andrea Aime
@geowolf
Technical Lead
Ah, this cannot work, or course:
SELECT
“pk”,
“percentage_change”,
encode(
ST_AsBinary (ST_Force_2D(“the_geom”)),
‘base64’
) AS “the_geom”
FROM
WHERE
“the_geom” && ST_GeomFromText (
‘POLYGON ((3972989.8359375 3248544.234375, 3972989.8359375 3270607.265625, 3980258.6640625 3270607.265625, 3980258.6640625 3248544.234375, 3972989.8359375 3248544.234375))’,
3035
AND (
“percentage_change” > - 0.828977
AND “percentage_change” <= - 0.463182
OR (
“percentage_change” > - 0.463182
AND “percentage_change” <= ‘-’
OR (
“percentage_change” > - 0.0973864
AND “percentage_change” <= 0.268409
OR (
“percentage_change” > 0.268409
AND “percentage_change” <= 0.634205
OR (
“percentage_change” > 0.634205
AND “percentage_change” <= 1.0
On Thu, Sep 4, 2014 at 11:16 AM, Jan Peters <petersjan@anonymised.com.> wrote:
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:Literal>
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
… 110 more
… 115 more
Position: 501
… 118 more
WITH (OIDS=FALSE)
Von: “Andrea Aime” andrea.aime@anonymised.com
An: “Jan Peters” petersjan@anonymised.com, “GeoServer Mailing List List” geoserver-users@lists.sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Looking at your style, there are still some - signs in the wrong places
On Thu, Sep 4, 2014 at 11:26 AM, Jan Peters <petersjan@anonymised.com> wrote:
SELECT
“pk”,
encode(
‘base64’
) AS “the_geom”
FROM
WHERE
3035
AND (
OR (
OR (
OR (
OR (
Gesendet: Donnerstag, 04. September 2014 um 11:18 Uhr
Betreff: Re: Re: Re: [Geoserver-users] SLD styling for negative values
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Sep 4, 2014 at 11:16 AM, Jan Peters <petersjan@anonymised.com.131…> wrote:
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:Literal>
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
… 110 more
… 115 more
Position: 501
… 118 more
WITH (OIDS=FALSE)
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ok, Andrea, I fixed the respective parts and now it works. So conclusio is:
  1. use: ogc:Literal-0.828977</ogc:Literal> for your negatives, not double nested
  2. turn on verbose logging in the Geoserver interface (Settings → Global) if you have any similar problems
Thanks again
Jan
On Thu, Sep 4, 2014 at 11:26 AM, Jan Peters <petersjan@anonymised.com.> wrote:
SELECT
“pk”,
encode(
‘base64’
) AS “the_geom”
FROM
WHERE
3035
AND (
OR (
OR (
OR (
OR (
Ing. Andrea Aime
@geowolf
Technical Lead
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:Literal>
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
se:Rule
se:Description
</se:Description>
ogc:And
</ogc:And>
</ogc:Filter>
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
</se:Rule>
… 110 more
… 115 more
Position: 501
… 118 more
WITH (OIDS=FALSE)
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
