Just tried out the nightly builds from days 26, 27 and 30 of March. The bbox
filter fix for SLD rules number greater than 20 works properly. But those
SLD that have less than 20 rules, only the first rule filter for a certain
scale it's picked up.
Example: there are 12 rules determined by maxscaledenominator=3406,
maxscaledenominator=5040 each one with a Filter(PropertyIsEqualTo) where
PropertyName(SUBTYPE) = 6 | 7 | 8 | 9 | 10 | 11.
The logs output this:
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - SELECT
GIRID,SCALE_FACTOR,SUBTYPE,ROTATION,COLOR,LOCATION as LOCATION FROM
CADREDE.GIR_INFRA_NODES WHERE (TYPE = ? AND (SDO_FILTER(LOCATION, ?) =
'TRUE' AND (SUBTYPE = ? OR SUBTYPE = ? OR SUBTYPE = ? OR SUBTYPE = ? OR
SUBTYPE = ? OR SUBTYPE = ? OR SUBTYPE = ? OR SUBTYPE = ? OR SUBTYPE = ? OR
SUBTYPE = ? OR SUBTYPE = ? OR SUBTYPE = ?)))
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 1 = 3
2009-03-30 11:10:50,268 DEBUG [org.geotools.data.oracle.sdo] - Using layer
SRID: 27492
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdb] - Setting paramtetr 2 as
MDSYS.SDO_GEOMETRY(2003,27492,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),MDSYS.SDO_ORDINATE_ARRAY(-44126.549504996605,108112.96023011261,-44021.28067295289,108112.96023011261,-44021.28067295289,108167.35853407085,-44126.549504996605,108167.35853407085,-44126.549504996605,108112.96023011261))
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 2 = POLYGON
((-44126.549504996605 108112.96023011261, -44126.549504996605
108167.35853407085, -44021.28067295289 108167.35853407085,
-44021.28067295289 108112.96023011261, -44126.549504996605
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 3 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 4 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 5 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 6 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 7 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 8 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 9 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 10 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 11 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 12 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 13 = 6
2009-03-30 11:10:50,268 DEBUG [org.geotools.jdbc] - 14 = 6
So the query resultset only contains records where SUBTYPE attribute is
equal to 6...there's something wrong, right?
regards,
Pedro Mendes
Pedro Mendes wrote:
Wow, a 27.000 lines SLD, that's the longest I've ever seen.
From what I see there you have a lot of different "subtypes"
and you need to display each of them with a different
symbol stored in a TTF symbol font, right?
[Pedro Mendes] Yep. It's simple: We need to display the elements (types)
with different sizes on 7 scales >> 1 element == 1 SLD file. Each element
can have 1 or more subelements (subtypes). If there is a type with 20
subtypes, the correspondent SLD could have up to 14*20 Rules. Why 14?
Because the necessity of built Rules on pairs, one for background
rendering
and other for foreground rendering.
Do you also need label conflict resolution? Otherwise you
may find a more compact solution using the dynamic symbolizer
features?
[Pedro Mendes] In this moment, yes, because of this issue:
http://www.nabble.com/SLD%3A-two-text-symboloizers-within-same-rule-td212107
78.html
But even with PointSymbolizer we'll have 7*20 Rules, so the issue will
persist.
http://blog.geoserver.org/2008/12/16/dynamic-symbolizers-part-2/
(that might require some changes in the data structure thought,
you'd need to have the symbol code stored in one of your
feature variables.
[Pedro Mendes] We already have the corresponding TTF character for each
subtype on database side, it should be just an update with character code.
Hmmm... looking at the code there should be some bug, the
renderer tries to build a filter out of the rules to limit
the amount of data it has to read, by or-ing the conditions
of each rule, but there is a limit of 20 rules, if that is
exceeded, it should give up and just use the bbox as the
filter. Indeed, I can confirm it's an issue, there is a bug
in the query building code inside the WMS renderer:
http://jira.codehaus.org/browse/GEOS-2781
I hopefully fixed it, can you double check by downloading
a nightly build starting from March 26? (the March 25 one
does not contain the fix):
http://gridlock.openplans.org/geoserver/1.7.x/
[Pedro Mendes] I'll do that.
And... was the problem actually solved? (don't remember)
[Pedro Mendes] I think so:
http://www.nabble.com/WFS-T-oracle-update-faild-on-GS-1.7.2-tp22331042p22331
042.html
Hmmm... nowhere. The extensions and GeoServer are developed hand in
hand, so an extension made for GeoServer 1.7.3 won't work for GeoServer
1.7.2.
OpenGeo provides the service of making custom bugfix build out
of older branches for customers of its support contract (among other
things).
Also, if you want to build your own, we can point you at the relevant
branches and the diffs and you can do the backport yourself.
Generally speaking, if anybody is interested in making custom bugfix
builds and share them with the community (say, release a 1.7.2.1,
1.7.2.2 and so on) we'll be happy to assist the effort providing
directions on how this can be done.
[Pedro Mendes] For the moment we'll just keep waiting for the bugs fix in
the nightly/stable versions.
Geoserver-users mailing list
View this message in context: http://www.nabble.com/SLD-Too-many-rules-filters--tp22684181p22780668.html
