On Tue, Feb 2, 2016 at 10:33 AM, Markus Innerebner <
mailinglist.innerebner@anonymised.com> wrote:
Hello everybody,
when trying to use the SLD transformation function -- used from the
geoserver manual example -- with floating point values geoserver is not
able to render. Is there a restriction with the attribute to have as data
type float values?
In case of that is there a workaround?
I'm not aware of such a restriction. Please provide more details about the
process, sld, and errors you're finding
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
