On Wed, Oct 8, 2014 at 11:34 AM, Jones, Spencer R <
srjones@anonymised.com> wrote:
Hi All
I’m in the process of getting our GeoServer up and running here, and I’ve
hit what is either a snag or a curio. If I edit one of the existing
pre-supplied styles (let’s say ‘line’), and I don’t change a single thing,
and then go to Validate, I get the following unexpected error:
- line 9: cvc-complex-type.2.4.a: Invalid content was found starting
with element 'sld:Abstract'. One of '{"http://www.opengis.net/sld":FeatureTypeStyle\}'
is expected.
To reiterate, these are the pre-supplied SLDs and they haven’t been edited
at all. Anyone have any idea what might be going on?
The built-in styles date back sometimes 8-10 years, and as you noticed not
all of them validate, but they fail validation
due to minor issues that do not prevent any functionality, so I would not
worry about it.
If anybody wants to remove those issues, please make a pull request against
the default data directory,
which is stored in github here:
https://github.com/geoserver/geoserver/tree/master/data/release
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
