Hey all,
I have this Heatmap I took from a fab website that shows how to use Heatmap SLD with a point layer. I have it working nicely but I am trying to change the weightAttr column on the fly using parameters
The SLD sheet is:
<?xml version="1.0" encoding="ISO-8859-1"?>
Heatmap
I’ve highlighted the parameter section in bold and I’m using the following additional text to the url:
¶meter:weightAttr: but it isn’t working (no errors)…have I got the syntax correct? I have created variables for SLD before which have worked which highly suggests I’ve missed something super simple.
If anyone can help I’d be grateful…
Many thanks
Ben
