On Fri, Sep 11, 2015 at 4:08 AM, Murad Jamal <muradjamal@anonymised.com> wrote:
Passing an Empty CDATA section didn;t work.
any other suggestions
Two:
1) Keep the mails on the mailing list
2) At this point I'm afraid some code debugging is needed. I can point you
to the relevant classes if you want?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
