[Geoserver-users] Slope process from wps-sextante
Dear list,
I’m trying to execute the slope base process from Sextante (using the community module wps-sextante built from source for the stable version) of a dem layer. The result doesn’t have any error in the logs but comes with all nodata values at -9999.
This happens also with different algorithm like aspect for instance. The only way that seems to solve this behavior is by saving the coverage to a file and then read it back before passing the coverage to the sestante algorithm. In fact if I write my own slope wps simply adding this further snippet:
// coverage is the input GridCoverage2D
//write coverage to file
Path writedir = Paths.get(new StringBuilder(“/tmp”).append(File.separatorChar).append(Slope.class.getSimpleName()).toString());
if (!Files.exists(writedir)) {
try {
Files.createDirectories(writedir);
} catch (IOException e) {
//fail to create directory
e.printStackTrace();
String filename = new StringBuilder(writedir.toAbsolutePath().toString()).append(File.separatorChar).append(cropped.getName().toString()).append(“.tiff”).toString();
final File writeFile = new File(filename);
writeToGeotiff(coverage, filename);
//read coverage from file
GridCoverage2D lCov = getLocalCoverage(writeFile.getName());
//writeToGeotiff
static void writeToGeotiff(GridCoverage2D cov, String fileName) {
try {
GeoTiffWriteParams wp = new GeoTiffWriteParams();
wp.setCompressionMode(GeoTiffWriteParams.MODE_EXPLICIT);
wp.setCompressionType(“LZW”);
ParameterValueGroup params = new GeoTiffFormat().getWriteParameters();
params.parameter(AbstractGridFormat.GEOTOOLS_WRITE_PARAMS.getName().toString()).setValue(wp);
File wfile = new File(fileName);
LOG.info(“wfile=”+wfile);
new GeoTiffWriter(wfile).write(cov, (GeneralParameterValue) params.values().toArray(new GeneralParameterValue[1]));
} catch (Exception e) {
LOG.severe(“exception while writing geotiff.”);
//getLocalCoverage
static GridCoverage2D getLocalCoverage(String filename) throws Exception {
File file = new File(“/tmp”+File.separatorChar+Slope.class.getSimpleName()+File.separatorChar+filename);
LOG.info("geotiff file to read "+file.toString());
AbstractGridFormat format = GridFormatFinder.findFormat(file);
GridCoverage2DReader reader = format.getReader(file);
GridCoverage2D coverage = reader.read(null);
LOG.info(“coverage=” + coverage);
return coverage;
then the process outputs a geotiff with expected slope values.
Obviously this is much more time consuming than expected and not good in term of performance. Does anybody know if there have been successful cases in the past with sextante algorithms and maybe has ideas why this is happening?
I’m open to improve and add this kind of test to the module if needed and then contribute back.
Thanks in advance for your help
Francesco
Dear list,
I’m trying to execute the basic slope process from Sextante (using the community module wps-sextante built from source for the stable version) of a dem layer. The result doesn’t have any error in the logs but comes with all nodata values at -9999.
try {
//writeToGeotiff
try {
//getLocalCoverage
return coverage;
Francesco
