[Geoserver-users] Slow startup of geoserver
I’m using GeoServer 2.8.0, with JVM version 1.7.0_80 (Java HotSpot™ 64-Bit Server VM). I’m also using Postgresql server version 9.4.0.
The problem is that when I restart geoserver with about 100 ImageMosaic stores already uploaded I see a time of about 2 seconds to load each layer.
In geoserver there are also other store like image pyramid, postgis store, etc, but they are loaded in less than 1 second.
Does anyone has suggestions about this problem?
Thank you for your help.
Best regards.
