Hi!
I have an Image Pyramid (GeoTIFF) in GeoServer 2.4.3 and I’m having problems with speed when accessing my top pyramid level.
The top tile has the following configuration:
Driver: GTiff/GeoTIFF
Files: f:\wms\RGB\4\608\160km_608_64.tif
Size is 100000, 100000
Coordinate System is:
PROJCS[“ETRS89 / UTM zone 32N”,
GEOGCS[“ETRS89”,
DATUM[“European_Terrestrial_Reference_System_1989”,
SPHEROID[“GRS 1980”,6378137,298.2572221010002,
AUTHORITY[“EPSG”,“7019”]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY[“EPSG”,“6258”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4258”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,9],
PARAMETER[“scale_factor”,0.9996],
PARAMETER[“false_easting”,500000],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AUTHORITY[“EPSG”,“25832”]]
Origin = (640000.000000000000000,6240000.000000000000000)
Pixel Size = (1.599999999999938,-1.599999999999938)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=YCbCr JPEG
INTERLEAVE=PIXEL
SOURCE_COLOR_SPACE=YCbCr
Corner Coordinates:
Upper Left ( 640000.000, 6240000.000) ( 11d15’41.73"E, 56d17’ 2.80"N)
Lower Left ( 640000.000, 6080000.000) ( 11d10’49.77"E, 54d50’51.00"N)
Upper Right ( 800000.000, 6240000.000) ( 13d50’19.10"E, 56d12’36.31"N)
Lower Right ( 800000.000, 6080000.000) ( 13d39’56.66"E, 54d46’38.35"N)
Center ( 720000.000, 6160000.000) ( 12d29’11.82"E, 55d32’10.85"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Overviews: 50000x50000, 25000x25000, 12500x12500, 6250x6250, 3125x3125, 1563x1
563
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
563
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
563
The GeoServer gives me the following log entries in Verbose_Logging – notice the approximately 1-minute gap in the processing:
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/nmap/wms]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - Mapping [/nmap/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 INFO [geoserver.wms] -
INFO | jvm 1 | 2014/01/16 10:15:27 | Request: getServiceInfo
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [geoserver.ows] - establishing raster style for nmap:wms_rgb
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [geoserver.wms] - setting up map
INFO | jvm 1 | 2014/01/16 10:15:27 | Request: getMap
INFO | jvm 1 | 2014/01/16 10:15:27 | Time =
INFO | jvm 1 | 2014/01/16 10:15:27 | Format = application/openlayers
INFO | jvm 1 | 2014/01/16 10:15:27 | Tiled = false
INFO | jvm 1 | 2014/01/16 10:15:27 | Buffer = 0
INFO | jvm 1 | 2014/01/16 10:15:27 | Palette = null
INFO | jvm 1 | 2014/01/16 10:15:27 | Filters = null
INFO | jvm 1 | 2014/01/16 10:15:27 | Filter = null
INFO | jvm 1 | 2014/01/16 10:15:27 | Width = 512
INFO | jvm 1 | 2014/01/16 10:15:27 | FeatureVersion = null
INFO | jvm 1 | 2014/01/16 10:15:27 | Height = 455
INFO | jvm 1 | 2014/01/16 10:15:27 | ValidateSchema = false
INFO | jvm 1 | 2014/01/16 10:15:27 | TilesOrigin = null
INFO | jvm 1 | 2014/01/16 10:15:27 | SRS = EPSG:25832
INFO | jvm 1 | 2014/01/16 10:15:27 | Styles = [StyleImpl[ name=raster]]
INFO | jvm 1 | 2014/01/16 10:15:27 | MaxFeatures = null
INFO | jvm 1 | 2014/01/16 10:15:27 | Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
INFO | jvm 1 | 2014/01/16 10:15:27 | RemoteOwsType = null
INFO | jvm 1 | 2014/01/16 10:15:27 | RemoteOwsURL = null
INFO | jvm 1 | 2014/01/16 10:15:27 | FormatOptions = {}
INFO | jvm 1 | 2014/01/16 10:15:27 | SldBody = null
INFO | jvm 1 | 2014/01/16 10:15:27 | Sld = null
INFO | jvm 1 | 2014/01/16 10:15:27 | SldVersion = null
INFO | jvm 1 | 2014/01/16 10:15:27 | Crs = PROJCS[“ETRS89 / UTM zone 32N”,
INFO | jvm 1 | 2014/01/16 10:15:27 | GEOGCS[“ETRS89”,
INFO | jvm 1 | 2014/01/16 10:15:27 | DATUM[“European Terrestrial Reference System 1989”,
INFO | jvm 1 | 2014/01/16 10:15:27 | SPHEROID[“GRS 1980”, 6378137.0, 298.257222101, AUTHORITY[“EPSG”,“7019”]],
INFO | jvm 1 | 2014/01/16 10:15:27 | TOWGS84[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0],
INFO | jvm 1 | 2014/01/16 10:15:27 | AUTHORITY[“EPSG”,“6258”]],
INFO | jvm 1 | 2014/01/16 10:15:27 | PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
INFO | jvm 1 | 2014/01/16 10:15:27 | UNIT[“degree”, 0.017453292519943295],
INFO | jvm 1 | 2014/01/16 10:15:27 | AXIS[“Geodetic longitude”, EAST],
INFO | jvm 1 | 2014/01/16 10:15:27 | AXIS[“Geodetic latitude”, NORTH],
INFO | jvm 1 | 2014/01/16 10:15:27 | AUTHORITY[“EPSG”,“4258”]],
INFO | jvm 1 | 2014/01/16 10:15:27 | PROJECTION[“Transverse_Mercator”, AUTHORITY[“EPSG”,“9807”]],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“central_meridian”, 9.0],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“latitude_of_origin”, 0.0],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“scale_factor”, 0.9996],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“false_easting”, 500000.0],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“false_northing”, 0.0],
INFO | jvm 1 | 2014/01/16 10:15:27 | UNIT[“m”, 1.0],
INFO | jvm 1 | 2014/01/16 10:15:27 | AXIS[“Easting”, EAST],
INFO | jvm 1 | 2014/01/16 10:15:27 | AXIS[“Northing”, NORTH],
INFO | jvm 1 | 2014/01/16 10:15:27 | AUTHORITY[“EPSG”,“25832”]]
INFO | jvm 1 | 2014/01/16 10:15:27 | Bbox = ReferencedEnvelope[659999.9999999899 : 749999.9999999864, 6160000.000000009 : 6240000.0000000065]
INFO | jvm 1 | 2014/01/16 10:15:27 | Env = {}
INFO | jvm 1 | 2014/01/16 10:15:27 | Angle = 0.0
INFO | jvm 1 | 2014/01/16 10:15:27 | CQLFilter = null
INFO | jvm 1 | 2014/01/16 10:15:27 | Elevation =
INFO | jvm 1 | 2014/01/16 10:15:27 | FeatureId = null
INFO | jvm 1 | 2014/01/16 10:15:27 | StartIndex = null
INFO | jvm 1 | 2014/01/16 10:15:27 | ViewParams = null
INFO | jvm 1 | 2014/01/16 10:15:27 | BgColor = java.awt.Color[r=255,g=255,b=255]
INFO | jvm 1 | 2014/01/16 10:15:27 | Transparent = false
INFO | jvm 1 | 2014/01/16 10:15:27 | Exceptions = SE_XML
INFO | jvm 1 | 2014/01/16 10:15:27 | Version = 1.1.0
INFO | jvm 1 | 2014/01/16 10:15:27 | Request = GetMap
INFO | jvm 1 | 2014/01/16 10:15:27 | RawKvp = {BBOX=659999.9999999899,6160000.000000009,749999.9999999864,6240000.0000000065, VERSION=1.1.0, FORMAT=application/openlayers, SERVICE=WMS, HEIGHT=455, REQUEST=GetMap, LAYERS=nmap:wms_rgb, STYLES=, WIDTH=512, SRS=EPSG:25832}
INFO | jvm 1 | 2014/01/16 10:15:27 | BaseUrl = http://wmsserver:8080/geoserver/
INFO | jvm 1 | 2014/01/16 10:15:27 | Get = true
INFO | jvm 1 | 2014/01/16 10:15:27 | RequestCharset = UTF-8
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/theme/default/style.css]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [geoserver.filters] - Compressing output for mimetype: text/css; charset=UTF-8
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/OpenLayers.js]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [geoserver.filters] - Compressing output for mimetype: application/x-javascript; charset=UTF-8
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/img/cancel.png]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png; charset=UTF-8
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/img/east-mini.png]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/options.png]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/img/south-mini.png]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/img/north-mini.png]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/img/west-mini.png]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/img/zoom-plus-mini.png]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [wms.map] - setting up 512x455 image
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [gce.imagemosaic] - Reading mosaic from file:/f:/WMS/RGB/4/4.shp
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [gce.imagemosaic] - Highest res 1.5999999999999377 1.5999999999999377
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 TRACE [gce.imagemosaic] - Adjusted Requested Envelope = ReferencedEnvelope[614999.99999999 : 794999.99999999, 6120019.53125 : 6279980.46875]
INFO | jvm 1 | 2014/01/16 10:15:27 | Requested raster dimension = java.awt.Rectangle[x=0,y=0,width=512,height=455]
INFO | jvm 1 | 2014/01/16 10:15:27 | Corresponding raster source region = java.awt.Rectangle[x=0,y=0,width=512,height=455]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [gce.imagemosaic] - Loading level 0 with subsampling factors 219 219
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [gce.imagemosaic] - Prepping to manage SortBy Clause
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [imagemosaic.catalog] - Index Loaded
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [data.shapefile] - Read lock: file:/f:/WMS/RGB/4/4.qix by ShapefileDataStore-4
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [data.shapefile] - Read lock: file:/f:/WMS/RGB/4/4.shp by ShapefileDataStore-4
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 TRACE [data.shapefile] - IndexFile has been opened. Number open: 1
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [data.shapefile] - Read lock: file:/f:/WMS/RGB/4/4.shx by org.geotools.data.shapefile.shp.IndexFile
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 TRACE [data.shapefile] - Memory mapping file…
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 TRACE [index.quadtree] - QuadTree opened
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [data.shapefile] - Read lock: file:/f:/WMS/RGB/4/4.shp by org.geotools.data.shapefile.shp.ShapefileReader
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 TRACE [data.shapefile] - Shapefile Reader has been opened. Number open: 1
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [data.shapefile] - Read lock: file:/f:/WMS/RGB/4/4.dbf by org.geotools.data.shapefile.dbf.IndexedDbaseFileReader
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 TRACE [data.shapefile] - Dbase File Reader has been opened. Number open: 1
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [gce.imagemosaic] - Thread:pool-1-thread-2 Loading raster data for granuleDescriptor Description of a granuleDescriptor
INFO | jvm 1 | 2014/01/16 10:15:27 | BBOX: ReferencedEnvelope[640000.0 : 799999.9999999937, 6080000.0000000065 : 6240000.0]file: file:/f:/WMS/RGB/4/608/160km_608_64.tifgridToWorld: PARAM_MT[“Affine”,
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“num_row”, 3],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“num_col”, 3],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“elt_0_0”, 1.599999999999937],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“elt_0_2”, 640000.8],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“elt_1_1”, -1.5999999999999348],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“elt_1_2”, 6239999.2]]Description of level 2
INFO | jvm 1 | 2014/01/16 10:15:27 | Description of a granuleDescriptor level
INFO | jvm 1 | 2014/01/16 10:15:27 | width: 100000
INFO | jvm 1 | 2014/01/16 10:15:27 | height: 100000
INFO | jvm 1 | 2014/01/16 10:15:27 | scaleX: 1.0
INFO | jvm 1 | 2014/01/16 10:15:27 | scaleY: 1.0
INFO | jvm 1 | 2014/01/16 10:15:27 | baseToLevelTransform: PARAM_MT[“Affine”,
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“num_col”, 3]]
INFO | jvm 1 | 2014/01/16 10:15:27 | gridToWorldTransform: PARAM_MT[“Affine”,
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“elt_0_2”, 640000.0],
INFO | jvm 1 | 2014/01/16 10:15:27 | PARAMETER[“elt_1_2”, 6240000.0]]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [gce.imagemosaic] - Loading level 0 with source region: java.awt.Rectangle[x=0,y=0,width=96877,height=74990] subsampling: 219,219 for granule:file:/f:/WMS/RGB/4/608/160km_608_64.tif
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 TRACE [gce.imagemosaic] - reading file: file:/f:/WMS/RGB/4/608/160km_608_64.tif
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/img/zoom-minus-mini.png]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/img/zoombar.png]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/openlayers/img/slider.png]
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [gce.imagemosaic] - We added the granule Description of a granuleDescriptor
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 TRACE [data.shapefile] - Shapefile Reader has been closed. Number open: 0
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 TRACE [data.shapefile] - Dbase File Reader has been closed. Number open: 0
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 TRACE [data.shapefile] - IndexFile has been closed. Number open: 0
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [gce.imagemosaic] - Producing the final mosaic, step 1, loop through granule collectors
INFO | jvm 1 | 2014/01/16 10:15:27 | 16 jan 10:15:27 DEBUG [gce.imagemosaic] - Using collector with filter:Filter.INCLUDE
INFO | jvm 1 | 2014/01/16 10:15:29 | 16 jan 10:15:29 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run…
INFO | jvm 1 | 2014/01/16 10:15:39 | 16 jan 10:15:39 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run…
INFO | jvm 1 | 2014/01/16 10:15:49 | 16 jan 10:15:49 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run…
INFO | jvm 1 | 2014/01/16 10:15:59 | 16 jan 10:15:59 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run…
INFO | jvm 1 | 2014/01/16 10:16:09 | 16 jan 10:16:09 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run…
INFO | jvm 1 | 2014/01/16 10:16:19 | 16 jan 10:16:19 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run…
INFO | jvm 1 | 2014/01/16 10:16:29 | 16 jan 10:16:29 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run…
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [gce.imagemosaic] - Adding to mosaic granule file:/f:/WMS/RGB/4/608/160km_608_64.tif
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [gce.imagemosaic] - Producing the final mosaic, step 2, final mosaicking
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [gce.imagemosaic] - Loaded bbox ReferencedEnvelope[640000.0 : 794999.99999999, 6120019.53125 : 6240000.0] while crop bbox ReferencedEnvelope[640000.0 : 794999.99999999, 6120019.53125 : 6240000.0]
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [geotools.rendering] - Drawing coverage GridCoverage2D[“RGB”, GeneralEnvelope[(639960.93749999, 6119667.96875), (795351.56249999, 6239902.34375)], DefaultProjectedCRS[“ETRS89 / UTM zone 32N”]]
INFO | jvm 1 | 2014/01/16 10:16:37 | ? RenderedSampleDimension(“RED_BAND”:[0.0 … 0.0])
INFO | jvm 1 | 2014/01/16 10:16:37 | ? ? Category(“No data”:[0.0 … 0.0])
INFO | jvm 1 | 2014/01/16 10:16:37 | ? RenderedSampleDimension(“GREEN_BAND”:[0.0 … 0.0])
INFO | jvm 1 | 2014/01/16 10:16:37 | ? RenderedSampleDimension(“BLUE_BAND”:[0.0 … 0.0])
INFO | jvm 1 | 2014/01/16 10:16:37 | ? Image=RenderedOp[“Scale”]
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [geotools.rendering] - Transforming coverage envelope with transform PARAM_MT[“Affine”,
INFO | jvm 1 | 2014/01/16 10:16:37 | PARAMETER[“num_row”, 3],
INFO | jvm 1 | 2014/01/16 10:16:37 | PARAMETER[“num_col”, 3]]
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [geotools.rendering] - Using interpolation javax.media.jai.InterpolationNearest@anonymised.com
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [geotools.rendering] - Raster Symbolizer
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 INFO [geoserver.wms] -
INFO | jvm 1 | 2014/01/16 10:16:37 | Request: getMap
INFO | jvm 1 | 2014/01/16 10:16:37 | Time =
INFO | jvm 1 | 2014/01/16 10:16:37 | Format = image/jpeg
INFO | jvm 1 | 2014/01/16 10:16:37 | Tiled = false
INFO | jvm 1 | 2014/01/16 10:16:37 | Buffer = 0
INFO | jvm 1 | 2014/01/16 10:16:37 | Palette = null
INFO | jvm 1 | 2014/01/16 10:16:37 | Filters = null
INFO | jvm 1 | 2014/01/16 10:16:37 | Filter = null
INFO | jvm 1 | 2014/01/16 10:16:37 | Width = 512
INFO | jvm 1 | 2014/01/16 10:16:37 | FeatureVersion = null
INFO | jvm 1 | 2014/01/16 10:16:37 | Height = 455
INFO | jvm 1 | 2014/01/16 10:16:37 | ValidateSchema = false
INFO | jvm 1 | 2014/01/16 10:16:37 | TilesOrigin = null
INFO | jvm 1 | 2014/01/16 10:16:37 | SRS = EPSG:25832
INFO | jvm 1 | 2014/01/16 10:16:37 | Styles = [StyleImpl[ name=raster]]
INFO | jvm 1 | 2014/01/16 10:16:37 | MaxFeatures = null
INFO | jvm 1 | 2014/01/16 10:16:37 | Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
INFO | jvm 1 | 2014/01/16 10:16:37 | RemoteOwsType = null
INFO | jvm 1 | 2014/01/16 10:16:37 | RemoteOwsURL = null
INFO | jvm 1 | 2014/01/16 10:16:37 | FormatOptions = {}
INFO | jvm 1 | 2014/01/16 10:16:37 | SldBody = null
INFO | jvm 1 | 2014/01/16 10:16:37 | Sld = null
INFO | jvm 1 | 2014/01/16 10:16:37 | SldVersion = null
INFO | jvm 1 | 2014/01/16 10:16:37 | Crs = PROJCS[“ETRS89 / UTM zone 32N”,
INFO | jvm 1 | 2014/01/16 10:16:37 | GEOGCS[“ETRS89”,
INFO | jvm 1 | 2014/01/16 10:16:37 | DATUM[“European Terrestrial Reference System 1989”,
INFO | jvm 1 | 2014/01/16 10:16:37 | SPHEROID[“GRS 1980”, 6378137.0, 298.257222101, AUTHORITY[“EPSG”,“7019”]],
INFO | jvm 1 | 2014/01/16 10:16:37 | TOWGS84[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0],
INFO | jvm 1 | 2014/01/16 10:16:37 | AUTHORITY[“EPSG”,“6258”]],
INFO | jvm 1 | 2014/01/16 10:16:37 | PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
INFO | jvm 1 | 2014/01/16 10:16:37 | UNIT[“degree”, 0.017453292519943295],
INFO | jvm 1 | 2014/01/16 10:16:37 | AXIS[“Geodetic longitude”, EAST],
INFO | jvm 1 | 2014/01/16 10:16:37 | AXIS[“Geodetic latitude”, NORTH],
INFO | jvm 1 | 2014/01/16 10:16:37 | AUTHORITY[“EPSG”,“4258”]],
INFO | jvm 1 | 2014/01/16 10:16:37 | PROJECTION[“Transverse_Mercator”, AUTHORITY[“EPSG”,“9807”]],
INFO | jvm 1 | 2014/01/16 10:16:37 | PARAMETER[“central_meridian”, 9.0],
INFO | jvm 1 | 2014/01/16 10:16:37 | PARAMETER[“latitude_of_origin”, 0.0],
INFO | jvm 1 | 2014/01/16 10:16:37 | PARAMETER[“scale_factor”, 0.9996],
INFO | jvm 1 | 2014/01/16 10:16:37 | PARAMETER[“false_easting”, 500000.0],
INFO | jvm 1 | 2014/01/16 10:16:37 | PARAMETER[“false_northing”, 0.0],
INFO | jvm 1 | 2014/01/16 10:16:37 | UNIT[“m”, 1.0],
INFO | jvm 1 | 2014/01/16 10:16:37 | AXIS[“Easting”, EAST],
INFO | jvm 1 | 2014/01/16 10:16:37 | AXIS[“Northing”, NORTH],
INFO | jvm 1 | 2014/01/16 10:16:37 | AUTHORITY[“EPSG”,“25832”]]
INFO | jvm 1 | 2014/01/16 10:16:37 | Bbox = ReferencedEnvelope[614999.99999999 : 794999.99999999, 6120019.53125 : 6279980.46875]
INFO | jvm 1 | 2014/01/16 10:16:37 | Env = {}
INFO | jvm 1 | 2014/01/16 10:16:37 | Angle = 0.0
INFO | jvm 1 | 2014/01/16 10:16:37 | CQLFilter = null
INFO | jvm 1 | 2014/01/16 10:16:37 | Elevation =
INFO | jvm 1 | 2014/01/16 10:16:37 | FeatureId = null
INFO | jvm 1 | 2014/01/16 10:16:37 | StartIndex = null
INFO | jvm 1 | 2014/01/16 10:16:37 | ViewParams = null
INFO | jvm 1 | 2014/01/16 10:16:37 | BgColor = java.awt.Color[r=255,g=255,b=255]
INFO | jvm 1 | 2014/01/16 10:16:37 | Transparent = false
INFO | jvm 1 | 2014/01/16 10:16:37 | Exceptions = SE_XML
INFO | jvm 1 | 2014/01/16 10:16:37 | Version = 1.1.1
INFO | jvm 1 | 2014/01/16 10:16:37 | Request = GetMap
INFO | jvm 1 | 2014/01/16 10:16:37 | RawKvp = {BBOX=614999.99999999,6120019.53125,794999.99999999,6279980.46875, VERSION=1.1.1, FORMAT=image/jpeg, SERVICE=WMS, HEIGHT=455, LAYERS=nmap:wms_rgb, REQUEST=GetMap, STYLES=, SRS=EPSG:25832, WIDTH=512}
INFO | jvm 1 | 2014/01/16 10:16:37 | BaseUrl = http://wmsserver:8080/geoserver/
INFO | jvm 1 | 2014/01/16 10:16:37 | Get = true
INFO | jvm 1 | 2014/01/16 10:16:37 | RequestCharset = UTF-8
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [geotools.image] - Encoding input image to write out as JPEG.
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [geotools.image] - Getting a JPEG writer and configuring it.
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [geotools.image] - Writing out…
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [geotools.image] - Writing out… Done!
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/jpeg
INFO | jvm 1 | 2014/01/16 10:16:37 | 16 jan 10:16:37 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
INFO | jvm 1 | 2014/01/16 10:16:39 | 16 jan 10:16:39 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run…
INFO | jvm 1 | 2014/01/16 10:16:49 | 16 jan 10:16:49 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run…
I have several other pyramids (other data, sizes etc.) running just fine and they are generated the exact same way – thus they should appear similar.
Can anyone shed some light on what is going on or how I can get more information?
Kind regards,
Casper
