Hi all!
I have two questions:
1) When using LineSymbolizer to style a line, it draws a straight line
between two (and more) points. Is there a way to make the line between
points to be smoother? When drawing e.g. contours, road lines or boarders
this would be a nice option. Please look at the contours in the attached
image, on left side is what I mean by "smoother" and on right hand side what
I get out of GeoServer.
<http://osgeo-org.1560.x6.nabble.com/file/n5071055/contours.png>
2) Could someone confirm, that <PerpendicularOffset> is not suitable for
labeling roads in a manner to get the label to follow the road on top of it?
Best regards,
Jakob
View this message in context: http://osgeo-org.1560.x6.nabble.com/Smoother-lines-with-LineSymbolizer-tp5071055.html
Hi Jakob,
You might want to try followLine:
http://docs.geoserver.org/stable/en/user/styling/sld-reference/labeling.html?highlight=followline#followline
It’s designed for non-straight lines.
Jonathan
On 6 August 2013 13:56, Jakob Ventin <jventin@anonymised.com> wrote:
Hi all!
- When using LineSymbolizer to style a line, it draws a straight line
image, on left side is what I mean by “smoother” and on right hand side what
- Could someone confirm, that is not suitable for
Best regards,
Jakob
Get your SQL database under version control now!
Version control is standard for application code, but databases havent
caught up. So what steps can you take to put your SQL databases under
version control? Why should you start doing it? Read more to find out.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Tue, Aug 6, 2013 at 2:56 PM, Jakob Ventin <jventin@anonymised.com> wrote:
Hi all!
what
We'd need a smoothing geometry transformation, something that we do not
have,
but we have a pluggable extension point where that code could be hooked
(so the difficulty is only in how sophisticated the smoothing algorithm
should be).
it?
followLine and perpendicularOffset do not mix, as we don't have a reliable
routing to compute line offsets (which is a hard problem to solve right)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
