[Geoserver-users] Software upgrade question - build information incorrect
hello
I am new to Geoserver, and have taken over an existing project. My first task is to upgrade the version of Geoserver which is running. Despite the fact that I have done this the Build Information still shows the old version number, and other associated information.
Apart from the fact that I uninstalled the old version from the server, and can clearly see the new version number as a service on the server, the Build Information is still the old information. I also noticed that the Contact Information had reverted back to Claudius Ptolemaeus.
Am I doing something wrong here, where is this build information derived from?
regards
shawn
I am not sure what to make of that Shawn, what application server are you using? It could of unpacked the earlier war somewhere - and still be running that unpacked version.
Same deal with the configuration reporting, it may be using the “default” data directory included with each war.
One of the steps when upgrading is to ensure your data directory (the configuration) is copied out of the webapps folder, the user manual gives you a few options on how to do this.
On 1 June 2016 at 11:25, Shawn Stanley <stanley1@anonymised.com> wrote:
hello
regards
shawn
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Jody Garnett
