Solved, it was just a typo in the layer identifier (case sensitivity was not taken care of). Sorry for the noise.
Von: Nachtigall, Jens (init) [mailto:Jens.Nachtigall@anonymised.com]
Gesendet: Dienstag, 30. Juni 2015 13:41
An: geoserver-users@lists.sourceforge.net
Betreff: [Geoserver-users] Layer creation using GeoServer Rest API fails with “invalid identifier” using Oracle
using geoserver manager (1.6.0) I ask the GeoServer REST API to create a new Layer. The Oracle DB throws an “ORA-00904: : invalid identifier” error. (We use http://docs.geoserver.org/latest/en/user/data/database/oracle.html, which works fine otherwise)
Here is the request that geoserver manager sents out to GeoServer:
<?xml version="1.0" encoding="UTF-8"?>true
EPSG:31468
-74.047185
40.882078
-73.90782
40.679648
EPSG:31468
shp_poly_landmarks
The Response I get is:
Bad response: code[500] msg[Internal Server Error] url[http://myserver.com:28081/geoserver/rest/workspaces/BNB/datastores/bnb/featuretypes] method[PostMethod]: :Error occurred creating table
Any ideas? Is this a bug in GeoServer or the GeoServer Oracle Plugin? I found this issue that PostGIS and Oracle handle identifiers in a different way (http://gis.stackexchange.com/questions/25829/publishing-oracle-spatial-table-in-geoserver) but I am not sure if this is related.
Best,
Jens
PS
Here is the traceback as printed by GeoServer (loglevel set to GEOSERVER_DEVELOPER_LOGGING)
2015-06-30 13:15:44,128 INFO [org.geoserver] - Loaded feature type ‘shp_poly_landmarks’, enabled
2015-06-30 13:15:44,129 WARN [catalog.impl] - Failed to load actual store for FeatureTypeInfoImpl[shp_poly_landmarks]
2015-06-30 13:15:44,199 ERROR [geoserver.rest] - :Error occurred creating table
2015-06-30 13:15:44,200 ERROR [geoserver.rest] -
org.geoserver.rest.RestletException: java.io.IOException: Error occurred creating table
at org.geoserver.rest.ReflectiveResource.handleException(ReflectiveResource.java:326)
at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:124)
at org.restlet.Finder.handle(Finder.java:296)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:650)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:620)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: Error occurred creating table
at org.geotools.jdbc.JDBCDataStore.createSchema(JDBCDataStore.java:757)
at org.geotools.jdbc.JDBCDataStore.createSchema(JDBCDataStore.java:144)
at org.geoserver.catalog.rest.FeatureTypeResource.handleObjectPost(FeatureTypeResource.java:137)
at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:121)
… 95 more
Caused by: java.sql.SQLSyntaxErrorException: ORA-00904: : invalid identifier
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:450)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:399)
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1017)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:655)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:249)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:566)
at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:202)
at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:45)
at oracle.jdbc.driver.T4CStatement.executeForRows(T4CStatement.java:933)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1075)
at oracle.jdbc.driver.OracleStatement.executeInternal(OracleStatement.java:1718)
at oracle.jdbc.driver.OracleStatement.execute(OracleStatement.java:1678)
at oracle.jdbc.driver.OracleStatementWrapper.execute(OracleStatementWrapper.java:332)
at org.apache.commons.dbcp.DelegatingStatement.execute(DelegatingStatement.java:264)
at org.geotools.jdbc.JDBCDataStore.createSchema(JDBCDataStore.java:749)
… 98 more
