[Geoserver-users] Some 1.4 problems
> 2. Geoserver starts up OK but if I try to look at a demo map with
the
> default data, I get this error:
> 274279 [INFO] org.vfny.geoserver.servlets.AbstractService - Had an
> undefined error: javax/media/jai/util/Range
> org.vfny.geoserver.wms.WmsException: javax/media/jai/util/Range
I figured out that JAI was either missing or unlocatable. I thought it
was
included, but I added the JAI libs to the
/webapps/geoserver/WEB-INF/lib/
folder and that takes care of that error.
Now when I try the demo, it goes through the normal motions -
PolygonHandler, StreamingRenderer, and then to AbstractService (MIME
type
PNG), then it aborts with a java.lang.IllegalStateException: STREAM
error.
Hit the send button too soon. Here's the error log.
Marc
966330 [INFO] org.vfny.geoserver.servlets.AbstractService - Service
handled
1059107 [FINE] org.vfny.geoserver.util.requests.readers.KvpRequestReader
- clean request is
service=WMS&request=GetMap&format=application/vnd.google-earth.kmz
XML&width=1024&height=1024&srs=EPSG:4326&layers=topp:parcelsha&styles=pa
rcels_style&KMScore=40&KMAttr=true&BBOX=-122.4484471768461,40.6535796555
5535,-122.3150880128115,40.75157043702733
- returning parsed {SRS=EPSG:4326,
BBOX=-122.4484471768461,40.65357965555535,-122.3150880128115,40.75157043
702733, LAYERS=topp:parcelsha, KMATTR=true, HEIGHT=1024, REQUEST=GetMap,
STYLES=parcels_style, KMSCORE=40, WIDTH=1024,
FORMAT=application/vnd.google-earth.kmz XML, SERVICE=WMS}
1059108 [FINE] org.vfny.geoserver.servlets.AbstractService - reading
request:
service=WMS&request=GetMap&format=application/vnd.google-earth.kmz+XML&w
idth=1024&height=1024&srs=EPSG:4326&layers=topp:parcelsha&styles=parcels
_style&KMScore=40&KMAttr=true&BBOX=-122.4484471768461,40.65357965555535,
1059109 [FINE] org.vfny.geoserver.global.Data - getting type
topp:parcelsha
1059109 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
1059110 [FINE] org.vfny.geoserver.wms.requests.GetMapKvpReader -
establishing parcels_style style for topp:parcelsha
1059122 [INFO] org.vfny.geoserver.wms.requests.GetMapKvpReader - Set
KMScore: 40
1059122 [INFO] org.vfny.geoserver.servlets.AbstractService - handling
request: org.vfny.geoserver.wms.requests.GetMapRequest@anonymised.com
1059123 [FINE] org.vfny.geoserver.servlets.AbstractService - strategy
is: FILE
1059616 [CONFIG] org.vfny.geoserver.wms.responses.helpers.JAISupport -
Supported JAIMapResponse's MIME Types: [image/jpeg]
1059617 [FINE] org.vfny.geoserver.wms.responses.GetMapResponse - setting
up map
1059642 [FINE] org.vfny.geoserver.servlets.AbstractService - mime type
is: application/vnd.google-earth.kmz
1068578 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
one hole in this polygon record
1074726 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1074727 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1074728 [INFO] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
Layer () rendered with KMZ raster output.
1074728 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
1074731 [FINE] org.vfny.geoserver.wms.responses.map.kml.KMLWriter -
encoded parcelsha
1074732 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
finished writing
1074733 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
setting up 1024x1024 image
1074895 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
setting to transparent
1074912 [FINE] org.geotools.renderer.lite.StreamingRenderer - Affine
Transform is AffineTransform[[7678.512439792381, 0.0,
940221.9248806731], [0.0, -10449.96258441672, 425852.38632315816]]
1074933 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
1074933 [FINE] org.geotools.renderer.lite.StreamingRenderer - processing
1 stylers for parcelsha
1074934 [FINE] org.geotools.renderer.lite.StreamingRenderer - creating
rules for scale denominator- 38332.05251133465
1074935 [FINE] org.geotools.data.shapefile.ShapefileDataStore - The DBF
file won't be opened since no attributes will be read from it
1076877 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1077869 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1077870 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1077871 [FINE] org.geotools.renderer.lite.StreamingRenderer - Style
cache hit ratio: 0.9998440424204617 , hits 6411, requests 6412
1078276 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML - KMZ
generated, it took18628 ms
1080210 [FINE] org.vfny.geoserver.wms.responses.GetMapResponse - asking
delegate for aborting the process
1080211 [FINE] org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer -
aborting KMZ map response
1080211 [INFO] org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer -
aborting KMZ encoder
1080211 [INFO] org.vfny.geoserver.servlets.AbstractService - Had an
undefined error: null
Sep 6, 2006 4:02:02 PM org.springframework.web.servlet.FrameworkServlet
processRequest
SEVERE: Could not complete request
        at org.mortbay.jetty.Response.getWriter(Response.java:459)
        at
org.vfny.geoserver.servlets.AbstractService.send(AbstractService.java:80
2)
        at
org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.ja
va:858)
        at
va:841)
        at
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.ja
va:583)
        at
org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:3
25)
        at
org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:173)
        at
org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:5
6)
        at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(Abs
tractController.java:139)
        at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handl
e(SimpleControllerHandlerAdapter.java:44)
        at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherS
ervlet.java:684)
        at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherSe
rvlet.java:625)
        at
org.springframework.web.servlet.FrameworkServlet.processRequest(Framewor
kServlet.java:392)
        at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.
java:347)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:747)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:860)
        at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:423)
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHan
dler.java:965)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharac
terEncodingFilter.java:122)
        at
dler.java:956)
        at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:353)
        at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:219)
        at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:542)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandler
Collection.java:145)
        at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.jav
a:126)
        at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:119)
        at org.mortbay.jetty.Server.handle(Server.java:245)
        at
org.mortbay.jetty.HttpConnection.handlerRequest(HttpConnection.java:365)
        at
org.mortbay.jetty.HttpConnection.access$1500(HttpConnection.java:38)
        at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConne
ction.java:609)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:486)
        at
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:196)
        at
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:296)
        at
org.mortbay.jetty.nio.SelectChannelConnector$HttpEndPoint.run(SelectChan
nelConnector.java:740)
        at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.ja
va:435)
1082891 [btpool0-20] ERROR org.mortbay.log - /geoserver/wms:
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
1082896 [btpool0-20] ERROR org.mortbay.log - /geoserver/wms
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
1189052 [FINE] org.vfny.geoserver.util.requests.readers.KvpRequestReader
- clean request is
rcels_style&KMScore=40&KMAttr=true&BBOX=-122.4485302646165,40.6535796555
5535,-122.3150340879958,40.75170537668358
1189053 [FINE] org.vfny.geoserver.util.requests.readers.KvpRequestReader
BBOX=-122.4485302646165,40.65357965555535,-122.3150340879958,40.75170537
668358, LAYERS=topp:parcelsha, KMATTR=true, HEIGHT=1024, REQUEST=GetMap,
1189054 [FINE] org.vfny.geoserver.servlets.AbstractService - reading
request:
_style&KMScore=40&KMAttr=true&BBOX=-122.4485302646165,40.65357965555535,
1189058 [FINE] org.vfny.geoserver.global.Data - getting type
topp:parcelsha
1189059 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
1189059 [FINE] org.vfny.geoserver.wms.requests.GetMapKvpReader -
1189061 [INFO] org.vfny.geoserver.wms.requests.GetMapKvpReader - Set
KMScore: 40
1189061 [INFO] org.vfny.geoserver.servlets.AbstractService - handling
1189061 [FINE] org.vfny.geoserver.servlets.AbstractService - strategy
is: FILE
1189063 [FINE] org.vfny.geoserver.wms.responses.GetMapResponse - setting
up map
1189063 [FINE] org.vfny.geoserver.servlets.AbstractService - mime type
1195841 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1203066 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1203067 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1203068 [INFO] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
1203069 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
1203070 [FINE] org.vfny.geoserver.wms.responses.map.kml.KMLWriter -
encoded parcelsha
1203070 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
finished writing
1203071 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
1203232 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
1203254 [FINE] org.geotools.renderer.lite.StreamingRenderer - Affine
Transform is AffineTransform[[7670.63166842225, 0.0, 939257.5739995276],
[0.0, -10435.592097833369, 425268.1746021528]]
1203373 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
1203373 [FINE] org.geotools.renderer.lite.StreamingRenderer - processing
1203374 [FINE] org.geotools.renderer.lite.StreamingRenderer - creating
rules for scale denominator- 38377.882032273475
1203375 [FINE] org.geotools.data.shapefile.ShapefileDataStore - The DBF
1205271 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1206143 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1206144 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
1206145 [FINE] org.geotools.renderer.lite.StreamingRenderer - Style
cache hit ratio: 0.9998441153546376 , hits 6414, requests 6415
1206648 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML - KMZ
generated, it took17584 ms
1208320 [FINE] org.vfny.geoserver.wms.responses.GetMapResponse - asking
1208320 [FINE] org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer -
1208321 [INFO] org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer -
1208321 [INFO] org.vfny.geoserver.servlets.AbstractService - Had an
Sep 6, 2006 4:04:11 PM org.springframework.web.servlet.FrameworkServlet
processRequest
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
1211003 [btpool0-20] ERROR org.mortbay.log - /geoserver/wms:
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
1211009 [btpool0-20] ERROR org.mortbay.log - /geoserver/wms
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
Marc Pfister
Geospatial Data Manager
ENPLAN
mpfister@anonymised.com
530/221-0440 x108
530/221-6963 Fax
Are you requesting KML? I have seen this error before with KML but I am unable to reproduce the error.
Brent Owens
(The Open Planning Project)
the
was
type
error.
Marc
handled
- clean request is
request:
topp:parcelsha
KMScore: 40
is: FILE
up map
encoded parcelsha
finished writing
processRequest
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
- clean request is
request:
topp:parcelsha
KMScore: 40
is: FILE
up map
encoded parcelsha
finished writing
processRequest
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
        at
2)
        at
va:858)
        at
va:841)
        at
va:583)
        at
25)
        at
        at
6)
        at
        at
        at
ervlet.java:684)
        at
rvlet.java:625)
        at
kServlet.java:392)
        at
java:347)
        at
        at
dler.java:965)
        at
        at
dler.java:956)
        at
        at
        at
        at
        at
a:126)
        at
        at
        at
        at
ction.java:609)
        at
        at
        at
        at
va:435)
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
