Hi List,
I try to update my publishing in geoserver but when I click to layers name and then publishing I receive this error:
It looks like you waited too long to make that last change.if this continues to happen, you should get in touch with your system administrator.
Go back to the home page and try again. …
I am really exhausted and I don’t know how to solve this.
Does anybody know how I can get ride of this problem?
Thanks
Cheers, Mandana
Hi Mandana,
I get some odd time-out bugs too that aren’t specifically because its actually timed out (its only second later!).
What web-browser are you using (I was thinking it was specific to Opera)? And what is your exact sequence of events?
Jonathan
On 5 June 2013 12:53, Mandana Mokhtary <mokhtary@anonymised.com> wrote:
Hi List,
Thanks
Cheers, Mandana
How ServiceNow helps IT people transform IT departments:
- A cloud service to automate IT design, transition and operations
- Dashboards that offer high-level views of enterprise services
- A single system of record for all IT processes
http://p.sf.net/sfu/servicenow-d2d-j
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
