[Geoserver-users] Sorting GetFeatureInfo-output
Hi All of You,
is there a way to sort the result of a GetFeatureInfo-output? I found
http://www.freemarker.org/docs/ref_builtins_sequence.html#ref_builtin_sort
but it seems not to match my problem.
Can anybody help?
With best wishes,
Tilo
Tilo Wütherich ha scritto:
Hi All of You,
That does not work because it works only on a list of primitive data,
a feature collection is not.
Unfortunately we have no way to grab a sorted result from feature info,
there is nothing in the wms spec talking about sorting. If the sort
is always the same and you're playing with a database, you can work
around this by creating a sorted view of your data and register the
view in geoserver as if it was a table.
Otherwise, I think we can consider mimicking wfs 1.1... I can't
remember, Justin, can you sort data using a WFS GetFeature GET request?
Yes... but in reality its not that well supported. The query object
passed to the geotools datastores has a sortBy option on it, but in
reality i believe only postgis actually supports it.
I guess we could add an additional parameter to the GetFeatureInfo
operation called sortBy, which basically does what wfs does. As far as I
know the getFeatureInfo calls through to wfs code anyways right? If so
it would seemles... with postgis anyways.
-Justin
!DSPAM:4007,474445b837662092453641!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
No it does not. The code path is different because it has to deal
with SLD filters and coverages and whatnot... It may be possible to
share a tiny part of the code with WFS, but really tiny in fact...
See also:
http://jira.codehaus.org/browse/GEOS-1479
Thank you, I think sorted views will do it for my purposes.
Tilo
