The current documentation about installing the SpatiaLite extension to Geoserver is misleading. Under the link on the 2.6 (same as latest / 2.7) documentation [1] site there is only the JNDI version available. But the docs just mention the non-JNDI setup.
Could you clarify which Spatialite extension one should use with Geoserver 2.6, and where it can be found? Though I’m trying to create my updated driver for Spatialite 4, I’m still puzzled what to use where.
Regards
Ben
References:
[1] http://docs.geoserver.org/latest/en/user/community/spatialite/index.html#spatialite-install
