[Geoserver-users] Spatio-temporal data represtation
Dear Geoserver users,
We would like to implement a web service of time series visualization of NDVI/RFE over our region of interest, where users can check the temporal profile at a pixel basis, and we will add the anomalies layer after,
What will be the best solution to implement such service using opensource solutions? i’ve tried the geoserver image mosaic structure (in the folder, geoserver will create a shapefile index, i’ve updated it with time attribute, but still GEOSERVER not recognizing the time attributes)? i’m seeking to insert the whole time-series in PostGIS database, add manually the dates and there interrogate that table via PHP , but still it’s difficult to get the most suitable solution,
All your comments, suggestions, orientations are the most welcome,
Thanks in advance,
Mustapha
De :geoserver-users-request@lists.sourceforge.netgeoserver-users-request@lists.sourceforge.net
À : geoserver-users@anonymised.comt
Envoyé le : Vendredi 10 avril 2015 13h18
Objet : Geoserver-users Digest, Vol 107, Issue 28
Send Geoserver-users mailing list submissions to
geoserver-users@anonymised.comts.sourceforge.net
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
geoserver-users-owner@lists.sourceforge.net
When replying, please edit your Subject line so it is more specific
than “Re: Contents of Geoserver-users digest…”
Today’s Topics:
  1. Re: geotiff import fails on geoserver 2.6.2 (Simone Giannecchini)
  2. How to set STRICT_PATH java system property variable -
    Migrating between GeoServer 2.5.x and 2.6.x procedure
    (Izabella Mancini)
  3. Memory Leak after deploying geoserver.war (Christoph Kleih)
  4. Re: Memory Leak after deploying geoserver.war (Andrea Aime)
Message: 1
Date: Fri, 10 Apr 2015 11:32:34 +0200
From: Simone Giannecchini <simone.giannecchini@anonymised.com…1107…>
Subject: Re: [Geoserver-users] geotiff import fails on geoserver 2.6.2
To: geobru <vbr@anonymised.com>
Cc: geoserver-users <geoserver-users@lists.sourceforge.net>
Message-ID:
<CAGY2-JOvPYhB_P22sMJFTUA_J6pQ=C_a4V7Rks8i=4rT3a+Meg@anonymised.com>
Content-Type: text/plain; charset=UTF-8
Dear Bruno,
you either have to send it in a private email or open a JIRA and
attach it to it.
I would go for the firs tone.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo ? consentito esclusivamente al destinatario del
messaggio, per le finalit? indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalit?
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Apr 10, 2015 at 11:28 AM, geobru <vbr@anonymised.com> wrote:
Hi Simone,
Of course.
Here is a sample, in attachment.
regards,
Bruno
201504100830_MSG3_IR_108_geotiff_grey.tif
<http://osgeo-org.1560.x6.nabble.com/file/n5200761/201504100830_MSG3_IR_108_geotiff_grey.tif>
View this message in context: http://osgeo-org.1560.x6.nabble.com/geotiff-import-fails-on-geoserver-2-6-2-tp5200744p5200761.html
BPM Camp - Free Virtual Workshop May 6th at 10am PDT/1PM EDT
Develop your own process in accordance with the BPMN 2 standard
Learn Process modeling best practices with Bonita BPM through live exercises
http://www.bonitasoft.com/be-part-of-it/events/bpm-camp-virtual- event?utm_
source=Sourceforge_BPM_Camp_5_6_15&utm_medium=email&utm_campaign=VA_SF
Geoserver-users@anonymised.comrceforge.net
Message: 2
Date: Fri, 10 Apr 2015 12:20:56 +0200
From: Izabella Mancini <izabellamancini0789@anonymised.com>
Subject: [Geoserver-users] How to set STRICT_PATH java system property
variable - Migrating between GeoServer 2.5.x and 2.6.x procedure
To: “geoserver-users@lists.sourceforge.net
Message-ID:
<CAHFvf4TwixxH+QLPbUycseb49hsRSM1ObypEM_u7+Gjachq2ew@anonymised.com>
Content-Type: text/plain; charset=“utf-8”
Hello GeoServer Community,
Currently, I upgraded GeoServer from 2.5.1 to 2.6.2 running in Apache2.4.6
Tomcat7 servlet on Ubuntu Desktop 14.04 LTS.
My test webgis application works fine with 2.6.2 so far without errors and
vector data are displayed in an OpenLayersMap.
I’m wondering how to set STRICT_PATH java system property variable which
appears to required for migrating data directory between GeoServer 2.5.x
and 2.6.x.
http://docs.geoserver.org/stable/en/user/datadirectory/migrating.html#migrating-between-geoserver-2-5-x-and-2-6-x
The catalog naming conventions became more strict in 2.6, invalidating
certain characters within names. This is because certain protocols will not
work correctly with certain characters in the name. In 2.6.3 and forward,
the naming restrictions are automatically set to relaxed through the
STRICT_PATH java system property variable. In order to ensure your names
will work with all protocols, set this variable to true.
java -DSTRICT_PATH=true Start
Could you help me with a short instruction, please?
Sincerely,
Izabella
An HTML attachment was scrubbed…
Message: 3
Date: Fri, 10 Apr 2015 13:28:33 +0200
From: “Christoph Kleih” <christoph.kleih@anonymised.com>
Subject: [Geoserver-users] Memory Leak after deploying geoserver.war
To: geoserver-users@anonymised.comet
Message-ID:
<trinity-c7be3281-0854-451b-8bb8-4c59efcb822d-1428665313290@anonymised.com.>
Content-Type: text/plain; charset=“us-ascii”
Message: 4
Date: Fri, 10 Apr 2015 14:09:18 +0200
Subject: Re: [Geoserver-users] Memory Leak after deploying
geoserver.war
To: Christoph Kleih <christoph.kleih@anonymised.com>
Cc: GeoServer Mailing List List
Message-ID:
<CA+nxMTsRwFJcuqwq9OMYAYPUFYzbZ29Ffs+yXqNKqRj-Q+rhtQ@anonymised.com>
On Fri, Apr 10, 2015 at 1:28 PM, Christoph Kleih <christoph.kleih@anonymised.com>
wrote:
Dear Geoserver Users,
I have deployed a new geoserver.war in a new tomcat instance. Currently I
cannot work with it, because my http/ajp mapping isn’t configured correctly.
Besides that, I get the following output in the catalina.out log. (see the
log below)
There seems to be a problem with a memory leak and the Threadpool.
Can you give me a hint what is going wrong and if that is a problem.
It’s a known issue without an easy solution, GeoServer is a complex, large
web applications
that uses a set of technologies which weren’t exactly meant to be used in a
webapp context (emf, jai).
I’ve tried to fix those errors spending a few days some years ago, without
any luck, and in time,
more of them piled up (since nobody managed to solve them all, and it does
not make a difference
if you get 1 or 100 of them, you still end up with a permgen leak).
The usual approach is to deploy GeoServer in its own private Tomcat, and
shut it down when
you need to redeploy. Not as bad as it sounds, considering that GeoServer
will force you to
increase the permgen settings anyways (at least 128m) and under load it
ends up eating a
good portion of your heap (each WMS request allocates a few megabytes of
heap for the
drawing surface, large ones can reach the tens of MB, by the time you have
some concurrent load
using a couple GB of memory is not uncommon)
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
loro utilizzo ? consentito esclusivamente al destinatario del messaggio,
per le finalit? indicate nel messaggio stesso. Qualora riceviate questo
utilizzarlo per finalit? diverse, costituisce comportamento contrario ai
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
End of Geoserver-users Digest, Vol 107, Issue 28
Hi Mustapha,
have you already tried the GeoServer tutorial about ImageMosaic with time series data?
Here you may find the link: http://docs.geoserver.org/latest/en/user/tutorials/imagemosaic_timeseries/imagemosaic_timeseries.html
Hope it helps,
Nicola Lagomarsini
2015-04-10 15:35 GMT+02:00 Mustapha Mimouni <mustapha_mimouni@anonymised.com>:
Thanks in advance,
Mustapha
De :geoserver-users-request@lists.sourceforge.net” <geoserver-users-request@lists.sourceforge.net>
À : geoserver-users@lists.sourceforge.net
Today’s Topics:
    (Izabella Mancini)
Message: 1
From: Simone Giannecchini <simone.giannecchini@anonymised.com>
Cc: geoserver-users <geoserver-users@anonymised.comsts.sourceforge.net>
Message-ID:
Dear Bruno,
attach it to it.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Simone,
Of course.
regards,
Bruno
Message: 2
Message-ID:
and 2.6.x.
Sincerely,
Izabella
Message: 3
Message-ID:
<trinity-c7be3281-0854-451b-8bb8-4c59efcb822d-1428665313290@anonymised.com>
Message: 4
geoserver.war
Message-ID:
log below)
web applications
shut it down when
will force you to
ends up eating a
heap for the
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Nicola Lagomarsini
Junior Software Engineer
