[Geoserver-users] Specify quantizer and caching options for a layer via Java API
[Sorry if a double post - my first message didn’t show up]
I’m adding data stores and layers in a WPS process. I’d like those layers to be tile-cached, non-antialiased and use the octree quantizer (non-default for this type of layer).
So two questions:
  1. Is there some way in the Java LayerInfo object (or some other catalog object) to force a layer to render as non-antialiased with the octree quantizer?
  2. How do I set attributes that appear on the Tile Caching tab of the layer admin pages, particularly the parameter filters, via the Java API?
I realize I can force the rendering options in WMS requests by adding this vendor param:
format_options=antialiasing:none;quantizer:octree
However, that causes caching misses without the appropriate GWC parameter filters set on the layer tile cache page (thus question #2).
Thanks in advance for any suggestions or pointers,
Eric Everman
CIDA - Center for Integrated Data Analytics
US Geological Survey
Middleton, WI
http://cida.usgs.gov/
Here is an example of my Java code adding a layer. How could I specify non-antialiased and the octree quantizer for this layer so that I don’t need to specify those options via WMS?
Map<String, Serializable> dsParams = new HashMap<>();
dsParams.put(“shapefile”, state.shapeFile.toURI().toURL());
dsParams.put(“dbase_file”, state.dbfFile.toURI().toURL());
dsParams.put(“namespace”, state.namespace.getURI());
dsParams.put(“dbase_field”, state.idFieldInDbf);
dsParams.put(“lastUsedMS”, System.currentTimeMillis());
DataStoreInfoImpl info = new DataStoreInfoImpl(catalog);
//A custom datastore created by Tom Kunicki
info.setType(DBASE_SHAPEFILE_JOIN_DATASTORE_NAME);
info.setWorkspace(state.workspace);
info.setEnabled(true);
info.setName(state.layerName);
info.setConnectionParameters(dsParams);
CatalogBuilder cb = new CatalogBuilder(catalog);
catalog.add(info);
DataAccess<? extends FeatureType, ? extends Feature> dataStore = info.getDataStore(new NullProgressListener());
List names = dataStore.getNames();
Name allData = names.get(0);
ProjectionPolicy srsHandling = ProjectionPolicy.FORCE_DECLARED;
cb.setWorkspace(info.getWorkspace());
cb.setStore(info);
FeatureTypeInfo fti = cb.buildFeatureType(dataStore.getFeatureSource(allData));
fti.setSRS(state.projectedSrs);
fti.setName(state.layerName);
fti.setTitle(state.layerName);
fti.setDescription(state.description);
fti.setAbstract(state.description);
fti.setProjectionPolicy(srsHandling);
cb.setupBounds(fti);
LayerInfo li = cb.buildLayer(fti);
if (state.defaultStyle != null) {
li.setDefaultStyle(state.defaultStyle);
catalog.add(fti);
catalog.add(li);
On Sun, Jan 18, 2015 at 3:25 PM, Everman, Eric <eeverman@anonymised.com> wrote:
So two questions:
Eric Everman
Middleton, WI
Eric Everman
Middleton, WI
651-269-4735
I was able to figure out an answer to my question, so I’ll post it here for others to find.
For Question 1, it looks like there is no answer: There is no way to set any sort of layer attribute that will affect rendering options that are available via WMS requests. Looking at the org.geoserver.wms package, its pretty clear that the ONLY attributes that are considered when choosing rendering options like which quantizer to use are set by the incoming WMS parameters.
For Question 2, I found my solution. Working from a LayerInfo instance, its possible to work with a related GeoServerTileLayerInfo instance. Here is a chunk of example code.
The gwc reference was passed in during Spring bean construction via the gwcFacade reference, e.g.:
RegexParameterFilter filter = new RegexParameterFilter();
filter.setKey(“format_options");
filter.setRegex(“.*");
filter.setDefaultValue(“antialiasing:none;quantizer:octree;”);
LayerInfo li = catalog.getLayerByName(“MyLayerName");
GeoServerTileLayer tileLayer = gwc.getTileLayer(li);
GeoServerTileLayerInfo tileLayerInfo = tileLayer.getInfo();
tileLayerInfo.addParameterFilter(filter);
On Mon, Jan 19, 2015 at 3:59 PM, Everman, Eric <eeverman@anonymised.com> wrote:
catalog.add(info);
cb.setStore(info);
catalog.add(fti);
catalog.add(li);
Eric Everman
Middleton, WI
Eric Everman
Middleton, WI
So two questions:
Eric Everman
Middleton, WI
On Thu, Jan 22, 2015 at 5:08 AM, Everman, Eric <eeverman@anonymised.com> wrote:
for others to find.
parameters.
Thanks for sharing. Sorry for the lack of a quick response, we're using all
non working hours to finish the
2.7-beta release
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
