One question: Do you seed the whole world or only BBOX of Germany? Resolution of level 17 is 1.1943 m and Germany is not a big country which makes me feel that 21 days is rather a long time. I have seeded the area of Finland to 0.5 m resolution from aerial images into 2 TB of tiles in about the same time which makes me feel that one week should be enough for you. However, I was seeding from an external WMS and you most probably have different hardware so our situations are not comparable.
I would absolutely divide the job into a bunch of smaller BBOXes. I have a feeling that the Seed missing tiles option is not always reliable but it can wrongly think that there is nothing more to seed. However, if you have been seeding for two weeks and all processes die it is not really reasonable to use the Reseed option. If a small job interrupts it does not pay so much to start it again.
Follow also the CPU load. Adding more seeding processed after the load is already close to 100% makes the overall speed just slower.
-Jukka Rahkonen-
Nachtigall, Jens wrote:
I have a 100MB shapefile with LINESTRINGs covering Germany, which I added as a cached layer. I use GeoServer 2.6.2 with included GeoWebCache 1.6.1 to seed tiles for layers 0-17 for the predefined EPSG_900913 gridset. On a server with 8 cores this process takes about 21 days.
I use Oracle Java 7 and JAI is installed. I’ve set “Number of tasks to use” to 8 (number of cpu cores).
Is there anything I can do to speed up the seeding process?
Best regards,
Jens
I’ve installed Marlin renderer now (only basic use as described at https://github.com/bourgesl/marlin-renderer/wiki/How-to-use#how-to-use-basic), still with Oracle Java 7. I also set the number of tasks to 16. I’ll see if this speeds things up.
@Jukka: Regarding the BBOX. I left the “Bounding box” field (subtext “These are optional, approximate values are fine.“) empty. I do not think that the bbox needs to be set here. The layer (based on the shapefile) already has a bounding box, so I would assume that GeoServer/GeoWebCache is intelligent enough to not try to render the whole world for a layer with restricted bounds. Correct me, if I am wrong.
Best,
Jens
Von: Rahkonen Jukka (MML) [mailto:jukka.rahkonen@anonymised.com]
Gesendet: Donnerstag, 26. März 2015 11:14
An: Nachtigall, Jens (init); geoserver-users@lists.sourceforge.net
Betreff: Re: Speeding up GeoWebCache seeding process
-Jukka Rahkonen-
Best regards,
Jens
