On Tue, Mar 31, 2015 at 7:29 PM, xavier lhomme <lhomme.xavier@anonymised.com>
wrote:
Hi
I think the bottleneck is not the rendering process but writing the tiles
to disk.
The reporter notes that the CPUs are pegged, so in his case, it does not
look like the disk is much of an issue.
In my little test it was hardly a problem too.
To improve the process of writing, we should used instead of the png
files, an equivalent ArcGIS Compact Cache, MbTiles or GeoPackage...
Yep, both well known direction for improvements, both in need of
sponsorship
The rendering process (I do not know what is used) can be expected to go
through a similar strategy to the vector tiling: i.e. store vectors in an
R-Tree and used the R-Tree to build the tiles.
Assuming you can keep the data in memory, which is not always the case...
in general GeoServer tries to stay the hell away from being memory bound,
but
an application that is dedicated to tile seeding could try to do that.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
