[Geoserver-users] Split label style in GeoServer CSS or SLD
Hello,
I would like to split the style of my labels, which consist of 2 attributes. I already managed to separate the lines, but I need to style them differently as well, as the second line should be bold. Unfortunately I’m running out of ideas, how it could work.
Currently my label looks like this:
IDENT
LOWERLIMIT
And I would like it to look like this:
IDENT (small)
LOWERLIMIT (bold)
I would prefer to do it in CSS, but I also prepared the style in SLD, so I would be happy for a solution in either of them.
My code looks like this in CSS:
label: [IDENT][LOWERLIMIT];
-gt-label-auto-wrap: 1;
font-weight: normal;
font-fill: black;
and like this in SLD:
ogc:PropertyNameIDENT</ogc:PropertyName><![CDATA[
ogc:PropertyNameLOWERLIMIT</ogc:PropertyName>
black
normal
Thanks for any help!
Michaela
Hi Michaela
I am not aware of any way of applying different text styles to different parts of a single text symbolizer.
One thing you could try is split the labels into two separate text symbolizers, and apply an offset equal to the font height to the second one.
So something like this:
black
normal
black
bold
0
14
I’m not too familiar with geocss, so I’m not quite sure how this would translate, but perhaps something like this:
label: [IDENT];
font-fill: black;
label: [LOWERLIMIT];
font-weight: bold;
font-fill: black;
label-offset: 0 14;
Torben
On Wed, Sep 20, 2017 at 7:03 AM, Egger Michaela <Michaela.Egger@anonymised.com.6862…> wrote:
Hello,
IDENT
LOWERLIMIT
IDENT (small)
LOWERLIMIT (bold)
font-fill: black;
black
normal
Michaela
Wichtiger Hinweis: Diese E-Mail Nachricht kann Betriebs- oder Geschäftsgeheimnisse oder sonstige vertrauliche Informationen enthalten. Wenn Sie nicht der Adressat sind und diese Nachricht irrtümlich erhalten haben, ist Ihnen eine Verwendung des Inhalts, eine Vervielfältigung oder Weitergabe dieser Nachricht ausdrücklich untersagt. Bitte benachrichtigen Sie uns und vernichten Sie die empfangene Nachricht. Vielen Dank. Please Note: This e-mail message may contain trade secrets or privileged, undisclosed or otherwise confidential information. If you are not the intended recipient and have received this message in error or by mistake any unauthorized use, reproduction or distribution of this message is strictly prohibited. Please notify us immediately and destroy the original transmittal. Thank you for your cooperation. Austro Control Österreichische Gesellschaft für Zivilluftfahrt mit beschränkter Haftung Sitz/Registered address: Wien/ Vienna; Registriert unter/registered under: FN 71000m Competent court/Firmenbuchgericht: HG Wien/commercial court Vienna; Rechtsform/legal form: GmbH Postanschrift/postal address: Wagramer Straße 19 - 1220 Wien/Vienna DVR: 0447277 ‬
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.com.382…sourceforge.net
On Wed, Sep 20, 2017 at 6:28 PM, Torben Barsballe <
tbarsballe@anonymised.com> wrote:
I'm not too familiar with geocss, so I'm not quite sure how this would
Thanks for following up Torben. I've updated your example to avoid the
second rule overriding the first:
    label: [IDENT], [LOWERLIMIT];
    font-weight: normal, bold
    font-fill: black;
       label-offset: 0 0, 0 14;
One thing that was not said here or on stackoverflow, is that the two
symbolizers are independent,
so depending on conflict resolution, you might get one label, the other, or
both, but there is
no way to make them be either both visible, or both invisible (that would
be a new feature for
the labeling engine, it's independent of the styling language chosen).
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
