[Geoserver-users] sql queries
No problem.
Since the sql queries is done with geotools and not with “native” geoserver sources, what is the best way to play around with it? Get the geotools sources, apply my changes, compile the stuff and put the jars in an existing geoserver installation? Does this workflow work?
Stefan
Von: Chris Holmes [mailto:cholmes@anonymised.com]
Gesendet am: Dienstag, 29. Januar 2008 21:56
An: Ziegler Stefan
Cc: geoserver-users
Betreff: Re: [Geoserver-users] sql queries
Ah, right. I misread ‘intersection’ as ‘intersects’, I apologize.
Chris
Ziegler Stefan wrote:
I’m quite sure that it works :wink: It would be more like a WPS. I hoped for
the cql_filter intersects command but this is returning the whole
geometry and is not clipping (which is correct).
Stefan
Gesendet am: Dienstag, 29. Januar 2008 21:32
An: Ziegler Stefan
Cc: aaime; geoserver-users
I’m 98% sure that’s still going to return the whole geometry. What you
really want is clipping of the polygon.
I’m not sure if there’s a command to do this in postgis. I searched a
bit and found this:
http://postgis.refractions.net/pipermail/postgis-users/2003-November/003437.html
Maybe that could help? If your data is really large splitting it up
could help…
Thanks. No no, everything works fine. I still have my own pdf output
problem. As geoserver requests always the whole feature the pdf gets
very big sometimes. Just wanted to hardcode a “select
intersection(bbox,the_geom)…” and see what happens (dull approach
though…).
Stefan
Von: Andrea Aime [mailto:aaime@anonymised.com]
Gesendet am: Dienstag, 29. Januar 2008 21:16
An: Ziegler Stefan
Cc: geoserver-users
Ziegler Stefan ha scritto:
Hi
can someone tell me where the sql queries are build in the sources for
the wms/wfs requests? Thanks.
Inside the datastores. OGC Filter representations are turned into
sql by SQLBuilder, FilterToSql and friends (hem, subclasses) whose
actual implementation depends on the dbms capabilities.
Trying to hunt down some misbehaviour?
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
!DSPAM:4005,479f8bab197215332866982!
!DSPAM:4005,479f90f5204711628642973!
Yup, that works great. You'll have to restart geoserver to make it pick up the changes. Building GeoTools can be a bit annoying, but once you get it working you just need to build the module you're working on and drop it in to GeoServer.
best regards,
Chris
No problem.
Since the sql queries is done with geotools and not with "native" geoserver sources, what is the best way to play around with it? Get the geotools sources, apply my changes, compile the stuff and put the jars in an existing geoserver installation? Does this workflow work?
Stefan
An: Ziegler Stefan
Cc: geoserver-users
Ah, right. I misread 'intersection' as 'intersects', I apologize.
Chris
I'm quite sure that it works :wink: It would be more like a WPS. I hoped for
Stefan
An: Ziegler Stefan
I'm 98% sure that's still going to return the whole geometry. What you
I'm not sure if there's a command to do this in postgis. I searched a
bit and found this:
could help...
> very big sometimes. Just wanted to hardcode a "select
> intersection(bbox,the_geom)..." and see what happens (dull approach
> though...).
> Stefan
> An: Ziegler Stefan
> Cc: geoserver-users
> > Hi
> Cheers
> Andrea
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
!DSPAM:4005,479f9582213101804284693!
