I am currently generating a layer with moving objects using data from a SQL table in Postgresql.
Is it possible to do the same using a resultset that is generated from a SQL select statement?
Thank you
Regards
Kim Sia
Extension: 3160
[This e-mail is confidential and may be priviledged. If you are not the
intended recipient, please kindly notify us immediately and delete the message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
Sim Kim Sia ha scritto:
Unfortunately not, out JDBC data store do not expose any way to run a direct SQL query. You're stuck with two possibilities:
* encoding your query as an OGC filter, if the query does not have joins
* prepare views that do the joins you need, and register the views as
feature types (you have to create the view, and then register its
geometric columns into the geometry_columns table).
Hi Andrea,
May I ask if my query is a
Select * from table_1, table_2 where table_1.a = table_2.a
would that work?
Is there a tutorial web page that explains how to encode a query as an OGC filter?
Thanks
how about
Regards
Kim Sia
Extension: 3160
----- Original Message ----- From: "Andrea Aime" <aaime@anonymised.com>
To: "Sim Kim Sia" <simksi@anonymised.com>
Cc: <geoserver-users@lists.sourceforge.net>
Sent: Wednesday, February 07, 2007 5:36 PM
Subject: Re: [Geoserver-users] SQL select statements to generate query layers
Hi Andrea,
would that work?
I did write:
>> have joins
The above is a join
The only way for you is to:
1) define a view that joins the tables:
create view MyJoinedView as
2) if table1.geom is a geometric column do an
insert into geometry_columns(...)
using the same parameters as for table1, but stating the
column is in MyJoinedView
3) in Geoserver register MyJoinedView as a feature type (you
may have to restart geoserver to have it notice your new view).
The OGC filters can then be used to add dynamic filtering conditions
such as show me only the features that have attributeA = 10 and things
like this (but no joins). If your filtering conditions are static, then
you don't need to use filter support at all, just add them in the
view definition, such as:
where table1.att1 = xxx and table2.att2 = yyy
Unfortunately we dont' have a tutorial on how to write OGC filters
afaik...
Hi Andrea,
I need to use the OGC filters for data from a single table.
Can you be more specific in your examples on using the OGC filters?
Thank you.
Regards
Kim Sia
Extension: 3160
Sent: Wednesday, February 07, 2007 5:55 PM
Hi Andrea,
would that work?
I did write:
>> have joins
The above is a join
afaik...
Hi Andrea,
Ok. The OGC Filter spec is a complex XML spec that allows to write
a "WHERE" like condition against a feature type.
You can find the full spec here: http://www.opengeospatial.org/standards/filter (there are lots of examples at the end of the paper).
Filter is used primarily by SLD (the map styling spec) and by
WFS, thought we have an initial support in WMS too.
You can find examples of SLD using OGC filters here:
http://docs.codehaus.org/display/GEOSDOC/SLD+Intro+Tutorial
http://docs.codehaus.org/display/GEOSDOC/SLD+Snippets
You can also find example OGC filters in most WFS sample requests
in the Geoserver web interface Demo section.
For using filters with WMS you have two possibilities:
* provide a full SLD, which includes both a filter and a styling,
in the SLD_BODY parameter. You can find a sample of this approac
among the sample requests, in the demo section (the sld looks funny
because it has been url-encoded, no < or > can appear in a GET request
* provide just a filter using the FILTER=xxx parameter, where xxx is
the url-encoded version of your OGC filter. If you need to specify
more than one filter, use comma as the separator, thought this will
change in 1.4.1 and 1.5.0, where we'll revert back to using ( ).
This one has been added recently and is not very well tested,
afaik due to a bug 1.4.0 allowed to specify just one filter, whilst
1.5.0beta2 allows multiple filters separated by comma.
Hope this helps
Hi Andrea,
thanks for your help.
From what I see,
the OGC filter requires me to specify a fixed value for the <literal> tag.
eg
<PropertyIsEqualTo>
<PropertyName>Person/Address/City</PropertyName>
<Literal>Toronto</Literal>
</PropertyIsEqualTo>
In the example above, I need to specify Toronto in advance.
Is there a way for OGC get a value that is determined by a javascript variable?
You can build the filter client side in javascript by string concatenation, so yes, you can do that. Unfortunately, I never coded in
javascript, so I can't provide you a sample. Keep the mails on the users mailing list, maybe someone else is able to help you.
Oh, btw, you can't use something like "Person/Address/City" in
Geoserver, since we don't support complex features (feature with nested
attributes). If you have a City attribute in the feature type you have to use <PropertyName>City</PropertyName>.
> provide just a filter using the FILTER=xxx parameter, where xxx is the url-encoded version of your OGC filter
I know about placing filter tags inside a sld file.
But since I have to generate string-concatenated filter using java script. I suppose I have to provide a filter using the Filter=xxx parameter
I suppose you are talking about something like this:
var url = ‘http://localhost:8080/geoserver/wms?filter=xxx’
yes?
Regards
Kim Sia
Extension: 3160
To: “Sim Kim Sia” <simksi@anonymised.com>
Sent: Thursday, February 08, 2007 3:58 PM
Hi Andrea,
a “WHERE” like condition against a feature type.
- provide a full SLD, which includes both a filter and a styling,
- provide just a filter using the FILTER=xxx parameter, where xxx is
change in 1.4.1 and 1.5.0, where we’ll revert back to using ( ).
Hope this helps
/> provide just a filter using the FILTER=xxx parameter, where xxx is the url-encoded version of your OGC filter/
Not necessarily, you can provide a full SLD document in your request using the SLD_BODY parameter. The Geoserver sample requests do contain
an example.
var url = 'http://localhost:8080/geoserver/wms?filter=xxx’
yes?
More or less, you have to add filter=xxx to your standard WMS request
(and you'll have to provide a filter for each layer, like you have to
provide a style for each one, separating them with commas, and adding
an empty one if a layer does not need to be filtered). As I told
you, this will work only in Geoserver 1.5.0beta2 onwards, 1.4.0 is
only able to support a single filter in a single layer request...
Hi Kim,
For your <PropertyIsEqualTo> filter, you will need several <and> tags wrapped around it to capture both person, city, and address.
In javascript you can just create a string and interject variables into it like so:
var person = "Joe"
var address = "123 Fake St."
var city = "Victoria"
var filter = " <ogc:Filter>"+
"<ogc:And>"+
"<ogc:PropertyIsEqualTo>"+
"<ogc:PropertyName>Person</ogc:PropertyName>"+
"<ogc:Literal>"+person+"</ogc:Literal>"+
"</ogc:PropertyIsEqualTo>"+
"</ogc:And>"+
"<ogc:PropertyName>Address</ogc:PropertyName>"+ <cid:part1.04050203.07070904@anonymised.com>
"<ogc:Literal>"+address+"</ogc:Literal>"+
"</ogc:And>"+
"<ogc:PropertyName>City</ogc:PropertyName>"+
"<ogc:Literal>"+city+"</ogc:Literal>"+
"</ogc:And>"+
"</ogc:Filter>";
Then send that filter along with your request.
Hope that helps,
Brent Owens
(The Open Planning Project)
Hi Andrea,
From what I see,
eg
<PropertyIsEqualTo>
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Hi Brent,
thanks for your reply.
I saw the following in a webpage http://docs.codehaus.org/display/GEOSDOC/1+How+a+GetFeature+Request+Works
filter=<ogc:Filter
xmlns:ogc="http://ogc.org" xmlns:gml="http://www.opengis.net/gml">
<ogc:BBOX>
<ogc:PropertyName>the_geom</ogc:PropertyName>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml">
<gml:coordinates>-73.99312376470733,40.76203427979042 -73.9239210030026,40.80129519821393</gml:coordinates>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>Granted that the example shown was using a wfs, instead of a wms.Should I include the Filter xmlns:ogc tags as well?Thank you.Regards
Kim Sia
Extension: 3160
----- Original Message ----- From: "Brent Owens" <brentowens@anonymised.com>
Cc: "Andrea Aime" <aaime@anonymised.com>; "geoserver users" <geoserver-users@lists.sourceforge.net>
Sent: Friday, February 09, 2007 12:13 AM
Hi Kim,
var person = "Joe"
"<ogc:And>"+
"</ogc:And>"+
"</ogc:And>"+
"</ogc:And>"+
"</ogc:Filter>";
Hope that helps,
Brent Owens
Hi Andrea,
From what I see,
eg
<PropertyIsEqualTo>
yes you should include all the namespaces for every tag that uses one. So if you are using <ogc:bbox> you should include the ogc namespace.
cheers,
Brent Owens
Sim Kim Sia wrote:
Hi Brent,
filter=<ogc:Filter
<ogc:BBOX>
</gml:Box>
</ogc:BBOX>
Kim Sia
Extension: 3160
Hi Kim,
var person = "Joe"
"<ogc:And>"+
"</ogc:And>"+
"</ogc:And>"+
"</ogc:And>"+
"</ogc:Filter>";
Hope that helps,
Brent Owens
Hi Andrea,
From what I see,
eg
<PropertyIsEqualTo>
