[Geoserver-users] Sql Server Error While connect
Hello;Dears
I start receving this error
Error creating data store, check the parameters. Error message: Unable to obtain connection: Cannot create PoolableConnectionFactory (The TCP/IP connection to the host 192.168.1.78, port 1433 has failed. Error: “connect timed out. Verify the connection properties. Make sure that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port. Make sure that TCP connections to the port are not blocked by a firewall.”.)
While connecting to mssql server and I know evry thing is ok and I can connect to sql server by the same user name and pass from any other machine
I’l using geoserver 2.5 snapshot come with boundless opengeo 4.1.1
Thank you
Khalid Omar
Structural Engineer
Dar Alkutby Consulting Office
No 13, 1st Floor, Nakhla Building
KING FAHAD ROAD
Jeddah
Khalid.Hanafy@anonymised.com…
Phone: +966 54 5400232
http://www.DarAlkutby.com
Description: cid:image04Please don’t print this e-mail unless you really need to.
On Tue, Nov 4, 2014 at 1:17 AM, Eng'r Khalid Omar <khalid.hanafy@anonymised.com>
wrote:
Hello;Dears
connection to the host 192.168.1.78, port 1433 has failed. Error: "connect
firewall.".)
I'l using geoserver 2.5 snapshot come with boundless opengeo 4.1.1
Hum... seems like a TCP/IP issue, are you connecting from other machines
using the TCP mechanism (which has
to be enabled in the SQL server config, it's not on by default as far as I
can remember).
Or it could be a local security issue, maybe the Java process is not
allowed to connect to other machines?
Hard to say.
By the way, this community supports only the normal GeoServer that can be
downloaded from geoserver.org,
for the one bundled with the OpenGeo suite you should ask on stackexchange,
as it's somewhat different
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
